Energy levels of partciles in a 3D box
The energy levels of a particle in a cubic box with side length 'a' are defined by the equation E = [(h^2 π^2)/(2 m a^2)] * (nx^2 + ny^2 + nz^2), where nx, ny, nz are integers greater than zero. The discussion clarifies that the lowest total energy configuration for 10 electrons must consider the Pauli exclusion principle, which allows only two electrons per quantum state due to spin degeneracy. The consensus is that the correct interpretation of the quantum numbers should exclude zero, leading to the conclusion that the lowest energy state is (1, 1, 1) for two electrons, and further configurations must be calculated to accommodate all 10 electrons.
  • Understanding of quantum mechanics and wavefunctions
  • Familiarity with the Pauli exclusion principle
  • Knowledge of energy quantization in quantum systems
  • Basic mathematical skills for manipulating equations
  • Study the concept of quantum states and energy levels in quantum mechanics
  • Learn about the implications of the Pauli exclusion principle on electron configurations
  • Explore the mathematical derivation of wavefunctions for particles in a box
  • Investigate the concept of spin and its role in quantum mechanics
Students and professionals in physics, particularly those studying quantum mechanics, as well as educators looking to clarify concepts related to particle behavior in confined spaces.
emilykay
Energy levels of a particle in cubic box with sides length a are:
E= [(h^2 pi^2)/(2 m a^2)] * (nx^2 + ny^2 + nz^2)
where nx, ny, nz are integers 0.
If 10 electrons are placed in this box, what is the lowest possible total energy of all the electron?
I am finding this question really interesting but I am stuck over one thing..
Why does it say "where nx, ny, nz are integers 0"
Surley this means that only 2 electrons can fit in the box, one spin up, one spin down?
I don't understand! please help...
Does is specifically say "where nx, ny, nz are integers 0" or is it some mathematical symbol that you have converted into words? (say, n_x, n_y, n_z \in \mathbb{Z} - \{0\})
It says "where nx, ny and nz are integers 0."
i think n_x=n_y=n_z=0 does mean, that all the electrons are in the ground state and as we know from Pauli's exclusion principle electrons (fermions) can only once occupy a quantum state which is specified by n and spin=\pm\frac{1}{2}. So as you noticed emilykay only 2 electrons can fit in the box, one spin up, one spin down
Okay, thanks for your help!
It seems a bit strange though how this question is kindof a trick question seeing as its asking about 10 electrons. and its worth 6 marks so i don't know how it can be a trick...
Does anyone else know?
Emily.
Hootenanny said:
Zero is not an integer.
you are right. the ground state energy is for n=1. maybe it should be n_x, n_y, n_z \not=0. so you should try all combinations and find the lowest possible energy
It is...
zero is an integer,
The lowest energy is (nx,ny,nz)=(0,0,0)
Yes, you are right, sorry my bad.
then you have to start at 0
thanks for your help. Definitly think its an error as the sentance doesn't really make sense.
I think it should read "where nx, ny, nz are integers not equal to zero". Consider the one-dimensional case. If n=0 then \psi=0 everywhere, and so the particle is not in the box. This can then be generalised to the 3D case, and thus ni must be non-zero.
I think the correct sentence is: "where n_x, n_y, n_z are integers not all equall to zero".
Usually you can have zero quanta in two directions for a particle. So what you need to do is to find the configuration of 10 particles that yields the lowest total energy. Remember that you must take into account the Fermi principle.
I would guess that there is a missing greater than sign in the problem, and that all of nx, ny, and nz have to be > 0.
Take a look at, for instance, http://en.wikipedia.org/wiki/Particle_in_a_box
While 0 is an integer, it's does not correspond to a valid solution. This can be deomnstrated by writing the appropriate expression for the wavefunction phi and imposing the boundary condition that phi=0 at the edge of the box.
The anwer to the problem is unique, if electron spin is taken into account. But there are several posibilities to take the triplet (n_{1},n_{2},n_{3}) to get the minimum energy.
Daniel.
It should definitely read greater than 0.
The wavefunction for a three-dimensional particle in a box is just three one-dimensional wavefunctions multiplied together. Thus, a zero for any of the three quantum numbers reduces the total wavefunction to zero. Therefore, the lowest energy state is (1, 1, 1) and two electrons can fit here because of spin degeneracy. The next highest energy is (2, 1, 1), (1, 2, 1), and (1, 1, 2), with two electrons in each state. Continue in this way to place the last two electrons, but be careful to make sure that it is really the next level and not a higher one. E.g., which is lower, (1, 1, 3) or (2, 2, 1)?
