Energy of driven damped oscillator
The discussion centers on the energy dynamics of a driven damped oscillator, specifically analyzing the equation of motion: m\ddot x + Dx = -b\dot x + F(t). The key insight is that energy is not conserved in this system due to the interaction with external forces and damping. The left-hand side of the derived equation represents the rate of change of total energy, which is not zero, contradicting the assumption of energy conservation. The conclusion emphasizes that in non-closed systems, such as this one, energy exchange with external forces must be accounted for, leading to a non-constant total energy.
  • Understanding of differential equations, particularly second-order linear equations.
  • Familiarity with concepts of kinetic and potential energy in oscillatory systems.
  • Knowledge of damping effects in mechanical systems.
  • Basic principles of energy conservation and non-conservative forces.
  • Study the effects of damping on harmonic oscillators in detail.
  • Explore the concept of driven oscillators and their energy dynamics.
  • Learn about the mathematical techniques for solving non-linear differential equations.
  • Investigate the role of external forces in mechanical systems and their impact on energy conservation.
Physicists, mechanical engineers, and students studying dynamics and oscillatory motion will benefit from this discussion, particularly those interested in the behavior of driven damped oscillators and energy transfer in non-conservative systems.
Marin
Hi all!
I was considering the Energy of a driven damped oscillator and came upon the following equation:
given the equation of motion:
m\ddot x+Dx=-b\dot x+F(t)
take the equation multiplied by \dot x
m\ddot x\dot x+Dx\dot x=-b\dot x^2+F(t)\dot x
and we rewrite it:
\frac{d}{dt}(\frac{m\dot x^2}{2}+\frac{Dx^2}{2})=-b\dot x^2+F(t)\dot x
now the LHS appears to be the total energy of the undamped harmonic oscillator, by energy conservation a constant, so it´s rate of change is 0:
0=-b\dot x^2+F(t)\dot x
Ok, so far so good :) But here lies my problem. Now we´ve obtained an equation for \dot x which we could solve for x(t). But the result appears to be different from the standart solution :(
0=\dot x(-b\dot x+F(t))
\dot x=0
-b\dot x+F(t)=0
=> \dot x_1=const:=C
x(t)=\frac{1}{b}\displaystyle{\int_{t_0}^{t}}F(t')dt'
so the solution would read: (would it? Do we have superposition here, since the DE is not linear any more?)
x(t)=C+\frac{1}{b}\displaystyle{\int_{t_0}^{t}}F(t')dt'
So could anyone please help me find the mistake :) I would be thankful :)
This is where you went wrong. The energy here is not conserved within the system, so you can't put the rate of change to zero. The SHM is a closed system, this is not. Here the energy keeps changing, the external force F(t) is pumping in energy while the damping is siphoning it out. Your equation tells you how this happens :
<br /> \frac{d}{dt}(\frac{m\dot x^2}{2}+\frac{Dx^2}{2})=-b\dot x^2+F(t)\dot x
But you can't put the LHS to zero, because energy is not being conserved. Suppose there was no external force and so the term F(t) was absent. The equation shows you how your energy would then decrease due to the damping term. And you know it must, because eventually it loses all the energy and stops.
So the moral of the story is : when your system is not closed, but interacting and exchanging energy with other systems (in this case whatever is doing the driving and the damping), you cannot use energy conservation for your system.
So it´s not like all the energy pumped in gets lost in damping, because this would imply a vanishing LHS?
the LHS isn't energy, but rate of change of it. If there is no driving term, eventually all the energy gets lost - and the thing comes to rest. Then as energy is changing no longer, the LHS is also zero. At this pint you can see that the rhs is also zero. Theoretically, this happens after infinite time.
Point is, the function of time on the LHS is not always zero, but becomes zero at t= infinity.
As already pointed out, the LHS is zero for an undamped oscillator. Let's take a look at the bracketed terms:
\frac{m\dot{x}^2}{2} = \frac{1}{2}mv^2 = T
\frac{Dx^2}{2} = V
The first term represents the kinetic energy, whilst the second term represents the potential energy. So the LHS represents the rate of change of the sum of the potential and kinetic energies, in other words the total energy. In this case of an undamped oscillator the total energy remains constant, however in the case of damped motion the total energy is not conserved.
  • · Replies 17 ·
