Energy Reference Frames: Consensus on Object Energy Across Different Observers?
40 replies · 7K views
Garth said:
"The failure of local energy conservation in the general theory was a problem that concerned people at that time, among them David Hilbert, Felix Klein, and Albert Einstein." - quoted from the Byers paper above.
Absolutely correct. And it has never been truly resolved, although theorists have constructed surrogates for energy which are conserved. But those surrogates are like epicycles, just constructed to have the properties desired.
And as for the spat over covariant, a Lorentz scalar is invariant, meaning it has the same value in all intertial frames.
You keep speaking of this as if it was still a problem when GR was finished. GR was 8 years in development. Even that paper you referenced states this. You simply cut that part off. The whole thing states
them David Hilbert, Felix Klein, and Albert Einstein. Noether's theorems
solved this problem.
Pete
"Noether's theorems solved this problem."
By showing that GR should not be expected to locally conserve energy - it is an example of an "Improper energy theory"!
Consider: You are an observer in an inertial frame of reference freely falling towards the Earth. You observe the Earth and measure its total energy, its rest energy and its kinetic energy. Over a period of time you notice that its kinetic energy is rapidly increasing as it accelerates towards you, or you might express this by saying its relativistic mass is steadily increasing.
However in GR there is no force acting on you, or the Earth, which in Newtonian physics would be described as a gravitational force, instead both you and the Earth are freely falling along your respective geodesics. These geodesics converge because of the curvature of space-time, as a consequence you and the Earth are accelerating towards each other.
In your inertial frame the Earth's energy is increasing but no work is being done therefore energy is not (locally) conserved.
Garth - I've already explained to you why that argument you posted is flawed. First off - even in Newtonian mechanics a particle in free-fall, as measured in the frame that you spoke of, is not conserved. I.e. in Newtonian language the gravitational field as measured in the free-fall frame, is a function of time and the energy of a particle in such fields is never constant. That follows from the fact that the potential energy of a particle in a time varying field is a function of time. When the potential energy is a function of time then the total energy is not conserved. In GR language this translates into "the components of the metric (aka gravitational potentials are functions of time" and I've already posted the proof that a particle in such a field does not have a constant energy. When the gravitational potentials are constant then I've posted a proof that the energy of a particle in free-fall is constant. The gravitational force on the object whose energy you're speaking of is not zero and hence work is being done on it. You're confusing thenotions of local flatness with the vanishing of the gravitational force in a curved spacetime. You're also neglecting gravitational time dilation and that plays a large role in definition of energy and thus on energy conservation. Please see
http://www.geocities.com/physics_world/gr/conserved_quantities.htm
I've already explained to you that (1) the energy of a complete system is always conserved locally and (2) the energy of a particle is conserve when the components of the metric tensor oare not explicit functions of time. I've already posted a link to the proof of the later. I don't see that I have anything more to post until you can find an errror in a calculations that I've posted . Right now you're simply repeating flawed a argument now. I've also already explained to you why that argument is flawed and you've totally ignored what I said and the proof's that I posted and now you're just repeating yourself and the same flawed argument. I've showed you how the energy of a particle in free-fall is defined in a spacetime and I've explained those circumstances under which the energy is conserved and posted the exact proof. Please explain to me why I should continue participating in this conversation when you're ignoring the proof's that I post?
Do you need me to repeat what I've posted? If you have forgotten what it was that I said and you don't wish to go back and read it then I'll be glad to post a detailed description of why your so-called proof is flawed. If you read the texts that you've quoted more carefully then you'll see what this "energy" is that they're talking about. Please tell me if you understand that the energy that they're referring to is E = P0 where P is the 4-momentum of a the particle in question.
Pete
I think it is you that is confused! Free falling means just that in the EEP. The theory of GR is either based on the EEP or it isn't.
Global energy is conserved, it is local conservation that we are talking about.
Your resolution may satisfy you but in my book it is a fiddle, I can always engage creative accountancy to balance my books by creating negative equity accounts, it may not satisfy the auditor though, they will want to see the money.
I believe Einstein and the others were right to be concerned.
The term 'gravitational potentials' does not refer to potential energy but to the components of the metric tensor, I believe that because the term has a verbal association with potential energy it may be misleading.
As the observer freely falls through the gravitational field, aka the curved space-time, around the Earth he/she experiences a metric that is time dependent because it is a function of his/her distance from the Earth. Therefore, according to the lecture notes you refer to, the time component of the energy-momentum vector -energy, is not conserved (locally).
You can think it but it won't make it true. What I've told you is basic GR. Any GRist will tell you the exact same thing that I've told you.
That is incorrect. You're confused on this point and what Einstein's equivalence principle is. It is now clear to me that this is the exact source of your confusion and why your argument is flawed. You stated that
Over a period of time you notice that its kinetic energy is rapidly increasing as it accelerates towards you, ...
You have specifically chosen a region of spacetime which is too large and now you cannot ignore tidal forces. You can ignore tidal forces if an only if you can ignore acceleration. Your entire argument is based on the acceleration of a particle in free-fall as observered in a free-fall frame. However since you said the kinetic energy is increasing then that statement implies the spacetime is curved and it implies you're not ignoring tidal forces.
In a curved spacetime Einstein's equivlence principle only says that the gravitational field can be transformed away at only one point in spacetime. That's the EEP as stated by Einstein himself.
I.e. when you transform to a free-fall frame as you have in your example, then the gravitational field has vanished only at one point in your frame of reference - the origin of your coordinate system. At points off the origin there is still a gravitational force. Since you have indicated that the particle you're observering is accelerating then you have not chosen to ignore tidal forces.
I assume that you have Weinberg's text. In chapter 3 please read section section 1 - Statement of the Principle then read section 2 - Gravitational Forces. This time don't skip by when Weinberg states what I've explained to you on page 68 in the third paragraph.
Although inertial forces don not exactly cancel gravitational forces for freely falling systems in an inhomogeneous or time-dependent gravitational field we can still expect an approximate cancelation if we restrict out attention to such a small region of space and time that the field varies very little over the region.
You've chosen not to make your region of space and time small enough to ignroe the gravitational forces and hence you can't claim that the gravitational forces is zero since it hasn't vanished.
Global energy is conserved, ..
Nobody knows if energy is conserved globaly. See
http://math.ucr.edu/home/baez/physics/Relativity/GR/energy_gr.html
Pete - I am not disputing the existence of tidal forces, and indeed their existence can question the validity of the EEP as you seem to indicate, and which is my intention in the first place, however these forces are second-order compared to the large Newtonian attraction that the curvature of space-time has replaced.
According to the theory this large gravitational force, as understood by Newton, has been replaced, and the work it did may no longer be used either to create or use potential energy. You will not find potential energy mentioned in Weinberg or MTW except in Weinberg's popular explanation of gravitational red shift, and then he says that it is "otherwise without foundation". It is the absence of gravitational potential energy that is at the core of the local non-conservation of energy.
As I said above the observer, freely falling towards the Earth, experiences a metric with time dependent components, and therefore, by your lecture notes, in that observer's frame of reference energy is not conserved.
Earlier you said you also have to take time dilation into account; this actually makes the situation worse.
As far as the global conservation of energy is concerned I was willing to allow that even though energy is a very slippery concept - for example how do you measure it at infinity? I am happy to accept Weinberg et al's calculations of the total energy of a static spherically symmetric Schwarzschild solution which turns out to be M - a constant. (G&C Eq. 8.2.16) [By the way I have now found Weinberg's explicit law of conservation of mass derived from the EEP - in the PNA - Eq. 9.3.2]
If you measure an increase in kinetic energy then you've measured a gravitational force.
Yes. I know that tidal forces is a second-order effect. One of the reasons for that is the magnitude. All that means is that the gravitational force in your free-fall frame is small. As such the kinetic energy change is small. That does not mean that the gravitational force is zero and it does not mean that the small gravitational force is not the source of the small changes in kinetic energy.
Mind you, there are various statements of the equivalence principle. It is rigorously stated as follows (as Einstein often spoke of it)
A uniform gravitational field is equivalent to a uniformly accelerating frame of reference.
Its the uniform gravitational field that you were speaking of, i.e. in a uniform gravitational field the entire field can be transformed away. That is not true for a non-uniform gravitational field. You have been speaking about a non-uniform gravitational field and the effects of the lingering gravitational forces and the changes in kinetic energy that it produces and therefore there is no problem with energy or the work that the field does. Although in the problem you spoke of energy isn't conserved in Newtonian physics anyway.
Pete
Garth, global energy is not in general conserved in GR.. Only in a few situations can it be made rigorous.
When you take the Schwarzschild metric and measure its 'global' energy, you are explicitly doing something known as the far field approximation, you are sort of measuring the energy relative to what all faraway stars would feel. Fortunately, this is an example where that procedure works, b/c the asymptotic limit is flat and the metric admits nice isometries.
If you want an easy example where global energy is meaningless, I invite you to write down the energy for a flat Friedmann Robertson Walker universe.
Thank you, that's what I meant when I said it was a slippery concept.
All I am doing is upholding Noether's insight that GR is not an example of Hilbert's "proper energy theorems"; it is an improper energy theorem. I was conceeding that globally energy may be thought of as conserved - in the Schwarzschild case - but that in general, in particular in the local case, it is not.
My work seeks to address this problem, basically by modifying GR and the EEP.
Garth said:
You can always choose a convention in which the allocation of changes in mass and energy are hidden. The question is, "Is this is a useful convention?". In the fission of a uranium atom the reallocation of potential energies releases a hell of a lot of energy and some would say the total mass of the fragments (consisting of more tightly bound components) is less than that of the original atom; but if your convention includes this energy in with those fragments as a total system then it tells you that no energy has been released. However, whether this is a useful way to describe the exposion of an atomic bomb or not is debatable to say the least.
You might try the sci.physics faq on "Does GR conserve energy"
link
One can, in GR, define the mass of an isolated system if certain conditions are met (the space-time is asymptotically flat).
But systems that are interacting gravitationally are tricky. You've noted that two bodies that are bound by nuclear forces have a different mass as a system because of the binding. The same applies for objects that are bound by gravitation, the system mass includes the binding energy. Unfortunately, one can't take a gravitationally bound system, and express its total energy as the sum of energies of mass1, mass2, and the energy of some sort of field. At least not in a way that's observer independent. There's some schemes for doing this in an observer dependent way (called pseudo-tensors, if I recall correctly) - but because different observers don't assign energy in the same way, these approaches are somewhat "ad-hoc".
So when one does something like separate two charged particles, which requires work, one can point to the electric field and say "the energy went into the electric field". When one separates two masses, one still changes the energy of the system, but one can't point to any specific location and say "the energy went there".
