Engineering Dynamics - Car Striking a Barrier
4 replies · 3K views
ConnorM
A car, assumed to be rigid and having a mass of 800 kg, strikes a barrel-barrier installation without the driver applying the brakes. From experiments the magnitude of the force of resistance F_r, created by deforming the barrels successive, is shown as a function of the vehicle penetration, s. If the car strikes the barrier traveling at a velocity v_c = 60 km/h, determine approximately the distance s to which the car penetrates the barrier.
http://imgur.com/LYc87dW - here is a picture of my question. This has the graph of how the barrels resistance force increases with s.
v_c = 60 km/h = 16.67 m/s
m = 800 kg
T (Kinetic energy) = 1/2 * mv^2
U_1->2 = ∫F ds
∑U_1->2 = T_2 - T_1
Starting off I assumed that once the car had reached the distance s it will have zero kinetic energy. So my equation became
∑U_1->2 = - T_1,
∫F ds = - 1/2 *mv^2, would my bounds of integration be 0 -> s ?
I don't really know what to do, am I using the right principles here?
on Phys.org
You got it somewhat figured out. Keep in mind the signs when simplifying this:
$$E_{\text{Final}} - E_{\text{Initial}} = \int \vec{F}(\vec{s}) \cdot \text{d}\vec{s}$$
OK so then I would have,
∫F ds 0 -> s = - 1/2 *mv2
∫F ds 0 -> s = 111,155.56 J
So from the graph, 40 kN x 0.75m = 30 J
Then I need 111,155.56 J - 30,000 J = 81,155.56 J,
so 60 kN x s = 81,155.56 J
s = 81,155.56 J / 60 kN
s = 1.35 m, then 1.35m + 0.75m = 2.10m
I did something similar, but I don't get how you end up with 111,155.56 J. -1/2 (800)(60)^2 = 1,440,000. I wanted to go about it the same way as you but as I added up the separate distances, they went past the graph and still didn't get close to the amount of energy needed. Can anyone please clarify this?
... 5 seconds later I realize we use m/s not km/h in SI, after spending two hours trying to figure it out... sorry thanks anyways
I think I'm taking the same dynamics course as you, I finished my CAP assignment yesterday so I might be able to help.
Remember Fr is opposite to the displacement therefore negative such that:
T1 + ∑U1→2 = T2
1/2mv^2 - Area = 0
Also you are measuring area so your units will be according to the graph "kN m" not "J" such that:
Area = 111155.56 N ft = 111.16 kN ft I also got "s = 2.10 m" as my final answer, so I'm assuming it's right.
