Enhance Visibility with Metal Spray Coating for X-Ray Applications
  • Context: Undergrad
  • Thread starter Thread starter Sylvester1
    Coating Spray X-ray
The discussion revolves around the use of metal spray coatings that are visible in X-ray applications. Participants explore various materials and methods for coating objects to enhance their visibility under X-ray examination, considering both practical and experimental contexts.
  • Experimental/applied
  • One participant inquires about the availability of metal spray coatings that can be detected by X-rays, specifically asking about gold and platinum sprays.
  • Another participant suggests that lead paint is effective for hospital X-ray machines and mentions that old paints can also be used for examining different layers in artworks.
  • Several participants request more details about the intended application, questioning the type of X-rays and the context in which the coated objects will be used.
  • There is a suggestion that the user might be looking for a fluorescence signature rather than just visibility in X-rays.
  • One participant notes that higher atomic number coatings will require less thickness to be visible in X-rays.
  • Another participant mentions that metal-oxide pigments from artists' paints, such as iron-oxide and zinc paints, may also work for visibility in X-rays.
  • A later reply indicates that an aluminum spray successfully achieved the desired visibility in X-rays.
Participants express varying opinions on the effectiveness of different materials and methods for achieving visibility in X-rays. There is no consensus on a single solution, as multiple approaches and materials are proposed and discussed.
Participants highlight the need for more specific details regarding the X-ray application, such as the type of X-ray machine and the conditions under which the coated objects will be examined. This suggests that the effectiveness of the proposed solutions may depend on these factors.
Sylvester1
Hello fellows,
i would like to ask if you might know any spray with metal elements which can be visible in X-rays.
I want to use it as coating in objects.
Does any common gold or plat spray be used?
Thank you!
Science news on Phys.org
Depends on the x-rays.
Lead paint works for hospital x-ray machines.
x-rays are often used to examine old paintings to see the different paint layers, so, in principle, any old paint will do.
thank you very much!can you suggest any link to find a spray suitable?
Can you describe what it is that you are trying to accomplish?
So far your question is ambiguous.
i want to detect object which are not visible in x ray by using x ray. In order to do that i am searching for a cheap and fast solution to coat these objets , with something visible in x ray. I would like to ask if the gold and plat spray paints can be visible in x ray. Or if there is another spray paint (a cheap coating) suitable for accomplishing this!
Not enough detail to advise properly.
How hard are you expecting these x-rays to be, for example?
Like airport x-ray scanners or the kind of thing a dentist may use?
How hidden is the painted object expected to be - i.e. is it in another x-ray transparent container, inside someone's body, underground... what?
Is the idea that someone with an x-ray machine will find the painted object easy to find or that the painted object should conceal its contents to an x-ray examination? Or is this preparation for a kind-of high tech treasure hunt or an art installation?
All this makes a difference.
Or perhaps you are looking for a fluorescence signature?
I've used x-rays for a variety of purposes, and have seen more:
imaging; fault detection; sorting scrap metal; generating electron cascades - I think the list is practically endless.
I've also used materials which are essentially transparent to x-rays in order to get x-rays generated inside of a vacuum chamber to the outside, where they could be conveniently measured. For this a low-z (low atomic number) material is required; we used beryllium windows.
So as Simon said, you will have to be much more specific.
I want a cheap coating method in order to coat a plastic object (i don't know what exactly, anything thin like a wire) and make it visible in an xray machine so that i can experiment with x ray techniques, like the one dentists use.
Then any metal coating should work, but higher atomic numbers will require less thickness. You can test various thicknesses by becoming friends with your friendly local dentist.
Even some of the heavier metal-oxide pigments of regular artists paint may even work. Iron-oxide and zinc paints are common enough - go to a store and ask.
Don't know why plastic and not just use a wire though.
Thank you very much! an aluminum spray did the work :)!
9K
