Undergrad Entropy after removing partition separating gas into two compartments
When an ideal gas is separated by a piston, the total entropy change upon removing the piston is initially thought to be the sum of the individual entropies. However, this is only valid if the temperatures and pressures in both compartments are equal, making the original question ill-posed. Discussions reveal that the Clausius inequality confirms that the entropy change during mixing is positive definite, but proving this using basic algebra poses challenges. The analysis suggests that the entropy change is dependent on three dimensionless parameters, which simplifies the evaluation of the entropy change to show it is always positive. Thus, the entropy change in mixing gases is confirmed to be positive definite under the right conditions.
burian
Summary:: Proving that entropy change in mixing of gas is positive definite
>An ideal gas is separated by a piston in such a way that the entropy of one prat is## S_1## and that of the other part is ##S_2##. Given that ##S_1>S_2##, if the piston is removed then the total entropy of the system will be..?
>Ans: ##S_1 +S_2##
After discussions with Chet Miller on stack exchange, it was concluded that the above answer is only possible if the initial temperature and pressure of the gas in each compartment is equal. Hence the question is illposed.
We can show that by clasius inequality that the entropy change is positive definite, but can we prove it us basic algebra?
I tried to prove it using my method here:
You are most probably right, for the thing about entropy. I tried writing my own proof. Let the compartment with greater temperature be ##T_2## and the other one be ##T_1##, let dQ be transferred from compartment with ##T_2## into one with ##T_1##:
$$−\frac{dQ}{T_2}+\frac{dQ}{T_1}=dS$$
s true for all points in the process. But, $$\frac{dQ}{T_1}>\frac{dQ}{T_2} $$ hence $$dS>0$$
The above method is is apparently wrong due the temperature being continuously at boundary hence ##T_1=T_2##... but couldn't we argue that this is the case for any heat transformed involved and hence there can never be any entropy gain?
I post Chet Miller's method till the part he had shown me:To get the final temperature and pressure, we use the conditions that the change in internal energy of the combined system is zero, and the final volume is equal to the initial combined volume. This leads to:
$$n_1C_v(T_F-T_1)+n_2C_v(T_F-T_2)=0$$and$$\frac{n_1RT_1}{P_1}+\frac{n_2RT_2}{P_2}=\frac{(n_1+n_2)RT_F}{P_F}$$The solutions to these equations for ##T_F## and ##P_F## are:
$$T_F=\frac{n_1T_1+n_2T_2}{(n_1+n_2)}\tag{1}$$$$\frac{1}{P_F}=\left(\frac{n_1T_1}{n_1T_1+n_2T_2}\right)\frac{1}{P_1}+\left(\frac{n_2T_2}{n_1T_1+n_2T_2}\right)\frac{1}{P_2}\tag{2}$$The entropy change for the system is given by:
$$\Delta S=n_1C_p\ln{\left(\frac{T_F}{T_1}\right)}+n_2C_p\ln{\left(\frac{T_F}{T_2}\right)}$$$$+n_1R\ln{\left(\frac{P_1}{P_F}\right)}+n_2R\ln{\left(\frac{P_2}{P_F}\right)}\tag{3}$$The next step is to show that, unless the initial temperatures and pressures are equal, this entropy change is positive definite.
Science news on Phys.org
>An ideal gas is separated by a piston in such a way that the entropy of one prat is$ S_1$ and that of the other part is $S_2$. Given that $S_1>S_2$, if the piston is removed then the total entropy of the system will be..?
>Ans: $S_1 +S_2$
You are most probably right, for the thing about entropy. I tried writing my own proof. Let the compartment with greater temperature be $T_2$ and the other one be $T_1$, let dQ be transferred from compartment with $T_2$ into one with $T_1$:
The above method is is apparently wrong due the temperature being continuously at boundary hence $T_1=T_2$... but couldn't we argue that this is the case for any heat transformed involved and hence there can never be any entropy gain?
The relationship dS=dQ/T only applies to a reversible change and this process is not reversible. So this argument doesn't work for an irreversible change. Besides, in this case, your dQ is internal to the system as a whole. If you want to apply the Clausius inequality to each of the bodies of gas individually (assuming they each retain their integrity during the process), then you would write $$\Delta S_1>\int{\frac{dQ}{T_B}}$$and $$\Delta S_2>-\int{\frac{dQ}{T_B}}$$where ##T_B## is the temperature at the interface between the two gas masses. Adding these together then yields: $$\Delta S_{Total}=\Delta S_1+\Delta S_2>0$$
So, if you accept the Clausius inequality, then no more work needs to be done.
If you wish to precisely determine the entropy change for this irreversible process and demonstrate that it is positive definite, then you need to approach this differently. The first step must be to establish the final state of the system at final thermodynamic equilibrium (using the 1st law of thermodynamics). Since entropy is a function of state, you cannot determine the entropy change without knowing the final state.
I have written a Physics Forums Insights article giving the recipe for determining the entropy change of a closed system experiencing any irreversible processes. It includes several examples to show how the method is applied to frequently encountered problems. Please check it out:
https://www.physicsforums.com/insights/grandpa-chets-entropy-recipe/
$$n_1C_v(T_F-T_1)+n_2C_v(T_F-T_2)=0$$and$$\frac{n_1RT_1}{P_1}+\frac{n_2RT_2}{P_2}=\frac{(n_1+n_2)RT_F}{P_F}$$The solutions to these equations for $T_F$ and $P_F$ are:
$$T_F=\frac{n_1T_1+n_2T_2}{(n_1+n_2)}$$$$\frac{1}{P_F}=\left(\frac{n_1T_1}{n_1T_1+n_2T_2}\right)\frac{1}{P_1}+\left(\frac{n_2T_2}{n_1T_1+n_2T_2}\right)\frac{1}{P_2}$$The entropy change for the system is given by:
$$\Delta S=n_1C_p\ln{\left(\frac{T_F}{T_1}\right)}+n_2C_p\ln{\left(\frac{T_F}{T_2}\right)}+n_1R\ln{\left(\frac{P_1}{P_F}\right)}+n_2R\ln{\left(\frac{P_2}{P_F}\right)}$$The next step is to show that, unless the initial temperatures and pressures are equal, this entropy change is positive definite.
The analysis represents the result of the first step in my recipe.
Likes burian and berkeman
I had gone through the article a long time back. I'll go through it again by around tomorrow. Some real life eventsare keeping me busy.
I've done a lot more work on this problem with some very interesting quantitative results, but before I post what I've done, I need you to sign off on the analysis I've presented so far.
https://www.physicsforums.com/insights/grandpa-chets-entropy-recipe/The analysis represents the result of the first step in my recipe.
Had been busy with some college entry related stuff but more or less done now. Reading the article, I realize that we don't really need the step of 'process devisation' here since we have entropy as a state function. We plugged in the variables already. Now, we just need to prove it's positive definite.
Seems a bit more difficult. I suppose maybe we could interpret the equation with a path and process then it could be intuitively concluded.
The entropy change, as expressed in Eqns. 1-3 of post #1 appears to be a function of the six independent parameters ##T_1##, ##T_2##, ##n_1##, ##n_2##, ##P_1##, and ##P_2## (each of which can vary between 0 and ##\infty##), and evaluating ##\Delta S## over these ranges (to show that it is always positive) would seem to be a daunting task, in reality it is a function only of the following three dimensionless parameters which vary over a very limited range: $$-1<\xi_T=\frac{(T_1-T_2)}{(T_1+T_2)}<1$$$$-1<\xi_P=\frac{(P_1-P_2)}{(P_1+P_2)}<1$$$$-1<\xi_n=\frac{(n_1-n_2)}{(n_1+n_2)}<1$$Evaluating ##\Delta S## over the limited ranges of only these 3 parameters is a much more manageable prospect.
Here is how it plays out:
Write $$T_1=\frac{1}{2}(T_1+T_2)+\frac{1}{2}(T_1-T_2)=\frac{(T_1+T_2)}{2}(1+\xi_T)$$
Similarly,$$T_2=\frac{(T_1+T_2)}{2}(1-\xi_T)$$$$\frac{1}{P_1}=\frac{1}{2}\left(\frac{1}{P_1}+\frac{1}{P_2}\right)(1-\xi_P)$$$$\frac{1}{P_2}=\frac{1}{2}\left(\frac{1}{P_1}+\frac{1}{P_2}\right)(1+\xi_P)$$$$n_1=\frac{(n_1+n_2)}{2}(1+\xi_n)$$$$n_2=\frac{(n_1+n_2)}{2}(1-\xi_n)$$
If we substitute there relationships into Eqns. 1 and 2 of post #1 for ##T_F## and ##P_F## we obtain: $$\frac{T_F}{T_1}=\frac{1+\xi_n\xi_T}{1+\xi_T}$$$$\frac{T_F}{T_2}=\frac{1+\xi_n\xi_T}{1-\xi_T}$$$$\frac{P_1}{P_F}=\frac{1-\lambda \xi_P}{1-\xi_P}$$$$\frac{P_2}{P_F}=\frac{1-\lambda \xi_P}{1+\xi_P}$$where $$-1<\lambda=\frac{n_1T_1-n_2T_2}{n_1T_1+n_2T_2}=\frac{\xi_n+\xi_T}{1+\xi_n\xi_T}<1$$
@burian Please check this over and see if you agree with it so far. Then I will continue with some calculated results.
Likes burian and vanhees71
This was a much harder exercise than I thought, I'll go over it carefully
What was your motivation for the substitutions you've made? To a beginner (me), it looks like an arbitary thing to do..
Well, there seemed to be too many parameters to do a reasonable number of calculations to test the entropy change. So I was willing to spend some time looking for ways to consolidate the variables to a reasonable number. I was also thinking about expressing the entropy change as a Taylor series in small parameters like I did in the 2nd example of the Insights article. Anyway, I've had lots of decades of experience doing modeling, and I always look for tricks to simplify things (as I was taught to do on the Tilden High School math team in 1958 and 1959).
Likes burian
Here is the continuation of the analysis.
As expressed by Eqn. 3 in post #1, the change in entropy of the system experiencing this irreversible process can be expressed as the sum of a temperature contribution and a pressure contribution: $$\Delta S=\Delta S_T+\Delta S_P$$where
$$\Delta S_T=n_1C_p\ln{\left(\frac{T_F}{T_1}\right)}+n_2C_p\ln{\left(\frac{T_F}{T_2}\right)}$$and $$\Delta S_P=n_1R\ln{\left(\frac{P_1}{P_F}\right)}+n_2R\ln{\left(\frac{P_2}{P_F}\right)}$$Expressed in terms dimensionless parameters, these become:
$$\Delta S_T^*=\frac{2\Delta S_T}{(n_1+n_2)C_p}=(1+\xi_n)\ln{\left(\frac{1+\xi_n\xi_T}{1+\xi_T}\right)}$$$$+(1-\xi_n)\ln{\left(\frac{1+\xi_n\xi_T}{1-\xi_T}\right)}$$
and$$\Delta S_P^*=\frac{2\Delta S_P}{(n_1+n_2)R}=(1+\xi_n)\ln{\left(\frac{1-\lambda\xi_P}{1-\xi_P}\right)}$$$$+(1-\xi_n)\ln{\left(\frac{1-\lambda\xi_P}{1+\xi_P}\right)}$$
Based on these, the dimensionless total entropy change is given by $$\Delta S^*=\Delta S_T^*+\frac{\gamma-1
}{\gamma}\Delta S_P^*$$
Note that the dimensionless temperature contribution to the entropy depends only on ##\xi_n## and ##\xi_T##, while the dimensionless pressure contribution to the entropy depends on all three ##\xi_n##, ##\xi_T##, and ##\xi_P##. I have carried out calculations on an Excel spreadsheet to evaluate the dimensionless temperature contribution as a function of its two parameters, and plotted this contribution as versus ##\xi_T## at a selection of values for ##\xi_n## over its allowable range. The results are presented in this Figure:
As can be seen, this dimensionless temperature contribution to the entropy change is positive for all values of its two parameters.
Likes burian
  • · Replies 19 ·
  • · Replies 22 ·
  • · Replies 32 ·
