Differentials of Entropy for Air and Water at Different Temperatures
The discussion focuses on the calculation of entropy changes for air and water at varying temperatures using the equations ΔS = ∓ ∫(C(T)/T)dT and ΔS_th = ∫(dQ/T_0)dT. Participants clarify that the integral for ΔS_th is incorrect due to the presence of two 'd' terms. They confirm that the correct expression for the universal entropy change (ΔS_univ) involves integrals that account for the specific heat capacity C(T) and the temperature differences during heating and cooling processes. The conversation emphasizes the need to express these changes in integral form as required by the problem statement.
  • Understanding of thermodynamic principles, specifically entropy and its calculations
  • Familiarity with integral calculus and differential equations
  • Knowledge of specific heat capacity (C(T)) and its role in thermodynamics
  • Basic concepts of heat transfer and temperature variations
  • Study the derivation and application of the entropy change formula in thermodynamics
  • Learn about the implications of specific heat capacity in energy transfer processes
  • Explore the differences in entropy calculations for various states of matter, particularly gases and liquids
  • Investigate the role of ambient temperature in thermodynamic systems and its effect on entropy
Students and professionals in thermodynamics, physicists, engineers, and anyone involved in heat transfer analysis and entropy calculations in physical systems.
yamata1
A bottle of water is removed from a cupboard at the initial temperature ##T_i##. In the ambient air of constant temperature ##T_0##, it warms or cools to reach equilibrium at the final temperature
##T_f = T_0##. The heat capacity of the plastic of the bottle is neglected compared to that of the water.
The thermal expansion of the water is also neglected.
a)The heat capacity C of the water depends on the temperature. Express entropy variations
##\Delta S## of water, ##\Delta S_{th}## of the air and ##\Delta S_{univ}## of the universe in the form of integrals.
b) Show that, whatever the temperatures, ##\Delta S_{univ}\geq 0##.
##dS=\frac{dQ}{T}##
for a)##\Delta S=\mp \int_{T_i}^{T_0}\frac{C(T)}{T}dT## and ##\Delta S_{th}=\int_{T_i}^{T_0}\frac{dQ}{T_0}dT## so ##S_{univ}=\Delta S_{th}+\Delta S##.
What is ##dQ## equal to ? I don't know how to answer question b).
Thank you for your help.
Your integral for ##\Delta S_{th}## makes no sense. You cannot have two 'd' terms in a single integral.
Hint: you do not need that integral at all.
Indeed,Is ##\Delta S_{th}=\mp\frac{Q}{T_0}=\mp\int_{T_i}^{T_0}\frac{C(T)}{T_0}dT ## correct ?
If so then question b) is ## \Delta S_{univ}=\int_{T_i}^{T_0}C(T)(\frac{1}{T}-\frac{1}{T_0})dT ## when the water heats up and ## \Delta S_{univ}=\int_{T_i}^{T_0}C(T)(\frac{1}{T_0}-\frac{1}{T})dT ## when it cools off .Both of these integrals are positive since C(T) is strictly positive.
True, but the question (part a) asks to express the entropy changes "in the form of integrals."
Since the ambient temperature does not change you cannot express the air's entropy change as an integral dT. What is the other option?
Ah, quite so.
Compare differentials dS for the air and for the water thruout the range of T.
