Entropy of N bits using Shannon entropy formula
  • Thread starter Thread starter T-7
    Bits Entropy
4 replies · 5K views
T-7
Hi,
This is a re-launch of an earlier question that I have narrowed down to just part a). I have also added my musings on it so far. This is all very new to me (and we haven't been given much in the lectures to go by [nor is there a course text]). I'd appreciate some help asap!
Lack of information is defined as
[tex]S_{info} = - \sum_{i} p_{i}log_{2}p_{i}[/tex]
([tex]p_{i}[/tex] is the probability of the outcome i). Calculate the entropy associated with the reception of N bits.
(This is very much blind guess work, but I expect that will become obvious...)
Ok. I take this to be a summation over an ensemble of possible arrangements, each with its own probability [tex]p_{i}[/tex].
Well, a bit is either on or off (1 or 0). 2 choices. Suppose I define [tex]\Omega_{i}[/tex] to be the number of ways of arranging the bits (microstates) for a case where there are x in state 1 and y in state 0 (a macrostate).
[tex]\Omega_{i} = \frac{N!}{x!y!}[/tex]
There are N bits. The sum is rolling from the first to the last possible outcome (macrostate). So rewrite
[tex]\Omega_{i} = \frac{N!}{(N-i)!i!}[/tex]
(So for [tex]\Omega_{first}[/tex] we have all the bits in, say, state 0. For [tex]\Omega_{last}[/tex] we have all the bits in the other state - state 1).
We're after the probability of each macrostate, I take it. So
[tex]p_{i} = \frac{\Omega_{i}}{total no. microstates} = \frac{\Omega_{i}}{2^N} = \frac{N!}{(N-i)!i!2^{N}}[/tex]
If that's true, I'd hope to be able to crunch
[tex]S_{info} = - \sum_{i} p_{i}log_{2}p_{i}[/tex] into an expression involving just N.
Am I right so far? Probably not.
( As it happens, I crunch it all the way down to
[tex]-Nlog_{2}N + N[/tex]
which is almost certainly wrong. But I need to work through it again... I'd better get this posted first :-)
Cheers!
Entropy is a quantity of a system, not an instance of that system.
Your N-bit message is described by some probability distribution and you should specify that prob. distribution first.
If we take a "Bernoulli"-type distribution, where the bits are independent and each is 1 with a probability of p and 0 with a probability of q=1-p, then
H(X1,X2,X3,...,XN) = H(X1) + ... + H(XN) (by independence)
and [tex]H(X_i) = -p \log (p) - (1-p) \log(1-p)[/tex]
so
[tex]H = N \left[ -p \log (p) - (1-p) \log(1-p) \right][/tex]
in particular, if p=1/2, [tex]H = N \log \left( 2\right)[/tex]
Assaf
http://www.physicallyincorrect.com/"
so
Assaf
Thanks for showing me how you got to the answer. It seems we are to explicitly use the formula above, however, working out a function pi and summing.
I probably need to look at your post again more carefully...
I don't quite understand what you mean by that, but if you'll elaborate I'll see if I can help.
Assaf
Assaf
Well, I have tried to work out a function pi to fit into [tex]S_{info} = - \sum_{i} p_{i}log_{2}p_{i}[/tex], and crunch the sum into something that is just a function of N. (apparently my function is mistaken, though it seemed logical?)
