Entropy of Ice Cube vs Room Temp Water
  • Context: Undergrad
  • Thread starter Thread starter zeromodz
    Entropy
The discussion centers around the comparison of entropy between an ice cube and room temperature water, exploring the concepts of entropy, temperature, and phase changes. Participants examine theoretical and conceptual aspects of entropy in relation to temperature and molecular organization.
  • One participant suggests that an ice cube may have more entropy than room temperature water due to its lower temperature, despite its more organized atomic structure.
  • Another participant argues that since entropy is a measure of disorder, the water, being at a higher temperature, should have greater entropy than ice.
  • A participant clarifies that the equation s = q / t is not entirely correct and provides an alternative formulation for understanding changes in entropy.
  • There is a question about the constancy of temperature when heat is added or removed, and whether the temperature refers to the ice cube or the water it is placed in.
  • Another participant explains that the temperature in question is the initial temperature of the object before heat is added, and speculates that different equations may apply to the ice cube and the water.
  • A more detailed explanation of entropy is provided, emphasizing that it relates to the number of distinct physical states of a system and how changes in energy affect entropy and temperature.
  • The concept of maximum entropy and its relation to the most probable distribution of molecular velocities is introduced, along with the idea of phase changes affecting entropy.
Participants express differing views on the relationship between temperature and entropy, with no consensus reached on whether an ice cube has more or less entropy than room temperature water. The discussion includes competing interpretations of relevant equations and concepts.
Some participants note limitations in the understanding of the equations and concepts discussed, particularly regarding the conditions under which they apply and the definitions of the systems involved.
zeromodz
Does an ice cube have more entropy than room temp water? I would intuitively think it doesn't because its atoms are more organized in a lattice vibrating like a solid. Conversely water would be more spread out and disorganized. However, the equation
s = q / t
states that the higher the temperature something has, the lower the entropy. So an ice cube would be colder than water making it have more entropy.
Science news on Phys.org
i think entropy us the measure of disorder an thus it increases when increasing temp and so also in this one the water has greater entropy than ice.
S is the CHANGE in entropy based on amount of heat added (Q) over the temp.
s = q / t
Where did you see this equation? It isn't quite correct. Instead, [itex]\Delta S=Q/T[/itex] holds for reversible systems at constant temperature; that is, the addition of thermal energy Q causes a change in entropy [itex]\Delta S[/itex] for a system at temperature T.
The entropy of a system increases with temperature: [itex]dS/dT=C/T[/itex], where C is the heat capacity (which is positive for typical materials).
How can the temperature stay constant if your adding it taking heat away? Also is T the temperaute of the water you drop the ice cube in or the ice cube itself
The temperature isn't staying constant. It is simply the temp that the object was initially at before you added heat.
I believe it is both. You would use a separate equation for each one. In one you would have a Q and in the other you would have -Q. But I don't know for sure, that's just a guess.
To understand entropy you must understand that when we speak of "a system" with specific macroscopic state variables we really mean a class of systems. So the "system" in this case is somewhat of an abstraction. The entropy then is a measure of how broad one's definition of "the system" is. Entropy is the negative logarithm of the number (or measure in a continuum case) of --in principle-- empirically distinct physical systems satisfy the conditions for this class we call "the system".
This is why entropy is both "a measurement of our knowledge" and yet physically meaningful and hence calculable for laboratory systems.
So start with "the system" being the class of n water molecules contained within a fixed volume and having a fixed total energy. Pick a distribution for the velocities of each molecule. You can then count actual distinct cases this system class may represent and this gives you the entropy. Change the distribution and you get a different entropy. Observe that there is a distribution yielding maximum entropy (because it has the most distinct cases) and it will also be the most probable given no other information.
See how the entropy changes as one varies the total energy and you get the (reciprocal) temperature. Note that you can possibly have a negative temperature if e.g. increasing energy actually decreases entropy. There is also the in-between case where increasing energy increases entropy in a constant fashion, thus both go up while temperature is constant. This occurs e.g. during a phase change like when ice is melting.
dE = TdS
Now the equation you wrote: s = q/t when applicable would mean that for fixed energy q, as the entropy increases the temperature decreases, or that for fixed entropy as energy increases so does temperature, or for fixed temperature entropy increases with energy.
Your intuition about the water is correct since the (constant T) phase change as ice melts (since also T is positive) with dQ = TdS and since we observe the need to increase energy to melt the ice, we then know melting increases entropy as well.
  • · Replies 19 ·
9K
16K
  • · Replies 53 ·
