Entropy of molten lead freezing
The discussion focuses on the entropy changes associated with the freezing of molten lead at 327.5 °C when poured onto a sidewalk at 20 °C. The latent heat of melting for lead is 24.1 J/g, leading to an entropy change of 4 J/K during the freezing process. The cooling of solid lead from 600.65 K to 293.15 K results in a decrease of entropy by 10 J/K. The total entropy change considers both the decrease in lead's entropy and the increase in the sidewalk's entropy, which absorbs the heat without a significant temperature change.
  • Understanding of thermodynamics, specifically entropy and heat transfer
  • Knowledge of latent heat and its implications in phase changes
  • Familiarity with the concept of thermal equilibrium
  • Basic calculus for integrating heat capacity over temperature
  • Study the principles of thermodynamic entropy and its calculations
  • Learn about latent heat and its role in phase transitions
  • Explore the concept of thermal equilibrium in heat transfer scenarios
  • Investigate the mathematical integration of heat capacity in thermodynamic processes
Students and professionals in physics, particularly those studying thermodynamics, as well as engineers and scientists involved in materials science and heat transfer applications.
jmm5872
Entropy of molten lead "freezing"
Lead melts at 327.5 C.° The latent heat of melting of lead is 24.1 J/g, and the heat capacity of solid lead is 0.14 J/g °C. You take 100 grams of molten lead at a temperature of 327.5 C° and pour it on the sidewalk. The lead freezes and then comes into thermal equilibrium with the sidewalk. The heat capacity of the sidewalk is so large that its temperature stays at 20 °C at all times. How much new entropy have you created by pouring the molten lead on the sidewalk and allowing it to freeze and cool to 20 °C?
Attempt:
This must be split up into two parts...the entropy created during the freezing process at constant temperature
Q = mL = (100 g)(24.1 J/g) = 2410 J
S = Q/T = (2410 J)/(600.65 K) = 4 J/K
The second part is the cooling of the solid lead from 600.65 K to 293.15 K...
ΔS = m\int^{Tf}_{Ti}(Cv/T)dT
ΔS = mCvln(Tf/Ti) = -10 J/K
I'm not sure about the signs...it seems like the entropy in freezing a liquid to a solid will decrease (get more ordered).
My other question is about the total entropy created...
Since the sidewalk can absorb all the heat energy that the lead releases does the entropy of the sidewalk technically increase, even though the sidewalk is large enough for the temp change to be negligable? In other words, is the amount of total entropy created the same as the decrease in entropy of the lead?
Thanks
Sorry, I just realized I need to take the Latent heat of melting and make it negative for freezing...this solves my first problem.
The temperature of the sidewalk does not change appreciably. But the sidewalk does absorb heat, so at the end of the process it is not in the same state that it was before the process started - it has absorbed the heat lost by the lead. It has absorbed this heat at essentially constant temperature. It is in the same state it would be in if this heat flow had occurred reversibly. Since there is reversible heat flow into the sidewalk, what can you say about the change in entropy of the sidewalk?
AM
