Equal Amplitude for Active Noise Control Headphones?
9 replies · 4K views
T.O.E Dream
Is the air pressure near an object making lots of noise (e.g. engine, speaker) higher than the air around it?
Going further, though, the fluctuations are more dramatic near the object, meaning it will have the highest highs, but again, equaly low lows.
If I understand it right sound means that the air pressure increases then decreases and so on? Is the more dramatic the fluctuations the louder the sound?
In other words if I had a device that measures air pressure it should be going up and down and up and down. And the further it goes up and down the louder the sound?
Yes. The amplitude of the wave is directly resultant in the volume of the sound.
You could label this diagram with air pressure notches up the Y-axis:
- 0 air pressure at the origin (lower left corner) of the graph
- low air pressure up the y-axis to the x-axis
- ambient air pressure at the x-axis
- high air pressure up the y-axis off the chart
The diagram represents a sound steadily increasing in volume from left to right.
And how does insulation lower the intensity of these fluctuations (i.e. lower the volume of the sound)?
Is this homework?
How do you think insulation affects the sound?
I'm wondering something about active noise control headphones. It says that the amplitude must be the same for the sounds to cancel out, does that mean the volume (or loudness) of the sound must be the same?
Yes.
