Electric Flux Equation for Rotating Loop?
The discussion centers on deriving the electric flux equation for a circular loop of radius r rotating with a constant angular velocity w in a uniform electric field E. The correct equation for electric flux as a function of time is established as Φ = Eπr²sin(wt), which accounts for the initial condition where the flux is zero at t=0. The confusion arises from the angle θ being defined incorrectly, as it should be π/2 at t=0, leading to the use of the sine function instead of cosine.
  • Understanding of electric flux and its mathematical representation
  • Familiarity with circular motion and angular velocity concepts
  • Knowledge of trigonometric functions, specifically sine and cosine
  • Basic principles of electromagnetism, particularly in uniform electric fields
  • Study the derivation of electric flux in rotating systems
  • Explore the relationship between angular velocity and electric fields
  • Learn about the implications of the sine and cosine functions in physics
  • Investigate applications of Faraday's law of electromagnetic induction
Students in physics, particularly those studying electromagnetism and rotational dynamics, as well as educators looking for clear explanations of electric flux in rotating systems.
Rijad Hadzic
A circular loop with radius r is rotating with constant angular velocity w in a uniform electric field with magnitude E. The axis of rotation is perpendicular to the electric field direction and is along the diameter of the loop.Initially, the electric flux through the loop is 0. Write an equation for the electric flux through the loop as a function of time in terms of r, E, and w.
So I use flux = EAcos(x)
A = pir^2
Epir^2 and cos x is going to vary with time, and this is where I should put w, angular velocity.
so flux = Epir^2cos(wt)
but my book is telling me its Epir^rsin(wt)
Why would it be sin? That's going against the flux equation..
At time ##t=0## the flux is zero but your equation gives
$$E\pi r^{2}\text{cos}(\omega\cdot 0)=E\pi r^{2}\neq 0$$
This is because your angle ##\theta## which you call ##x## is defined incorrectly. At time zero, ##\theta=\pi/2##, so how would you correct this?
I see. So starting at t = 0, my equation would give me the flux if Area vector and E are pointing in the same direction, which would be the maximum flux, but the problem is saying at t= 0, E is perpendicular to the surface, so flux should be 0..
so using (E)(3.14...)(r)^2sin(wt), my inital flux would be 0, and this is the correct function.
Is my understanding right now?
Yes, because sin is shifted over from cos by ##\pi/2##.
