Equation of 3d vector question
  • Thread starter Thread starter canadian_beef
    3d Vector
6 replies · 8K views
canadian_beef
Find an equation of the line through the point A (4,5,5) which meets the line (x-11)/3 = (y+8)/-1 = z-4 at right angles.
well i know that the direction of the given line is d(3,-1,1) and the original line crosses through the point (11,-8,4)
The direction of the new line must be able to dot with the old line to get 0 (thus right angles).
I don't know how to find a direction that i know will pass through A.
Help or hint please
You can write any point P on the given line in parametric form, e.g. (x = t, y = a function of t, z = another function of t). Then you can write the direction of AP in terms of t.
So, you have point A and point P (P on the line). what can you do with the orthogonal projection of AP onto the given line? from there, how can you find a vector that points from the line to A and that is orthogonal to <3,-1,1> ?
There are two common ways to write a vector equation of a line:
i. Given two points, say P and Q, an equation of the line through P and Q (in that order as t ranges over [0,1]) is given by
[tex]\vec{r}(t)=\vec{Q}t+\vec{P}(1-t)[/tex] or [tex]\vec{r}(t)=\vec{P}+\left(\vec{Q}-\vec{P}\right) t[/tex]​
notice that [tex]\vec{Q}-\vec{P}[/tex] is a vector in the direction of the line, hence
ii. Given a point and a vector in the direction of a line, say point P and vector [tex]\vec{v}[/tex], we have an equation of the line through P and parallel to [tex]\vec{v}[/tex] is given by
[tex]\vec{r}(t)=\vec{P}+\vec{v} t[/tex]​
Any vector, <a,b,c>, perpendicular to <3, -1, 1> must satisfy 3a-b+ c= 0 or c= b- 3a. Such a line passing through (4, 5, 5) must be of the form (x-4)/a= (y- 5)/b= (z-5)/(b- 3a). Now, what are the conditions on a and b, in order to ensure that (x-4)/a= (y- 5)/b= (z-5)/(b- 3a) intersects (x-11)/3 = (y+8)/-1 = z-4 ?
couple questions
shouldnt there be a D value such that 3a-b+c+d=0
and how do i make sure they intersect
canadian_beef said:
couple questions
cant I just make up any A and B values and it will work?
