Equation of plane given points
  • Thread starter Thread starter ParoXsitiC
    Plane Points
The problem involves finding the equation of a plane that contains multiple points in three-dimensional space: (1,1,5), (3,5,3), (8,8,1), (10,2,2), (18,6,-1), and (-1,-3,6). The original poster attempts to use vectors derived from three of these points to determine the normal vector of the plane and subsequently formulate the plane's equation.
  • Exploratory, Assumption checking
  • Participants discuss calculating vectors from points and using the cross product to find the normal vector. There are attempts to validate the resulting plane equation with various points, leading to questions about the consistency of the points being coplanar.
Participants are actively engaging with the problem, checking calculations, and questioning the assumptions about the points being coplanar. There is no explicit consensus on the validity of the plane equation derived, as discrepancies arise when testing different points.
There is uncertainty regarding whether all six points are intended to lie on the same plane, given the nature of the problem and the number of points provided.
ParoXsitiC
Find equation of plane containing points: (1,1,5),(3,5,3),(8,8,1),(10,2,2),(18,6,-1),(-1,-3,6)
Find 2 vectors given 3 points, using a common point. The cross product of these 2 vectors will be the normal vector of the plane. Use normal vector coords <a,b,c> as coefficients in the ax+by+cz=d formula where x,y,z is any point in the plane and solve for d. This equation better be true for all points.
P = (1,1,5)
Q = (3,5,3)
R = (8,8,1)
PQ = <2,4,-2>
PR = <7,7,-4>
PQ x PR = <-2,-6,14>
Plug in point P into formula and get:
-2x-6y+14z = 62
Test formula by plugging in Q and don't get 62.
Check the z-component of your cross product result.
Okay I had 14 when should be -14
PQ x PR = <-2,-6,-14>
-2x-6y+14z = -78
Now point Q works out to be -78 but the point (10,2,2) turns out to be -60
Is this a trick question?
-2x-6y+14z = -78
I just used point p and the normal vector we now agree on to form the equation of a plane and got something different than what you have. You might have messed up the algebra.
I forgot to update the formula with -14:
-2x-6y-14z = -78
Still when using (10,2,2) I get -60 and not -78
-2x-6y-14z = -78
Yeah that is weird, are you sure they mean all the points are in the same plane?
That is how it is worded, reading it word for word. I thought it was weird too given 6 points instead of the common 3
  • · Replies 20 ·
17K
12K
