Equations of motion of an electron emitted from a surface
The discussion revolves around the equations of motion for an electron emitted from a surface, considering various geometries such as an infinite plane or a finite plate. Participants explore the implications of the electric field produced by these surfaces and how it affects the electron's trajectory, with a focus on both theoretical and practical aspects relevant to real-world applications.
  • Homework-related
  • One participant describes the scenario of an electron emitted from a surface held at a positive potential and seeks the equations of motion for this case.
  • Another participant questions the electric field produced by an infinite charged plane and its implications for the electron's motion.
  • Some participants suggest that the infinite plane approximation simplifies the problem, leading to a parabolic trajectory, while others caution that this may not hold true if the electron travels significant distances from the surface.
  • There is a discussion about the necessity of knowing the electric field as a function of position, particularly for finite plates, and how this affects the calculations of the electron's motion.
  • One participant proposes treating the problem as a parallel plate capacitor, suggesting that this might provide a more accurate model for the electron's behavior in a vacuum chamber.
  • Participants express uncertainty about the relevance of the potential difference and the gradient of the electric field in determining the electron's trajectory.
  • There are inquiries about the initial kinetic energy of the electron in relation to the potential of the plate, and how this influences the equations of motion.
Participants do not reach a consensus on the best approach to model the electron's motion. Multiple competing views exist regarding the validity of the infinite plane approximation and the necessary conditions for accurate calculations.
Limitations include the need for more information about the system, such as the charge density on the plate and the gradient of the potential. The discussion highlights the complexity of the problem and the dependence on specific parameters that have not been fully defined.
This discussion may be of interest to those working in fields related to electromagnetism, particle physics, or anyone involved in experimental setups involving electron emissions and electric fields.
NB76
Homework Statement: Real world application of freshman physics
Relevant Equations: TBD
This is not a homework question, this is relevant to my work. It seems simple enough (introductory) but I keep running into problems.
An electron is emitted from an surface (material is irrelevant, could be an infinite pane, could be a disk, etc.). The plane is held at a potential V (V > 0, electron is attracted back to the surface). The initial kinetic energy is KE. The angle of emission is alpha. What are the equations of motion for the electron?
What is the field produced by an infinite charged plane?
If there is a hint in there it is not obvious to me. What is the field form an infinite charged plane?
This is a real problem. The plane is actually 2 cm x 2 cm. I am trying to be flexible in my acceptance of how the problem is set up. If an infinite plane allows for a simple solution I want to see and understand that solution and it's limitation. If there is a better (simpler) geometry that would enable a simpler calculation I want to see and understand that solution and it's limitation.
You mentioned infinite plane as a possibility, and that is the simplest case. The field is constant, so it will be a parabolic trajectory, just like a stone thrown in a local gravitational field.
Otherwise it will depend on how far the electron can get from the surface. If it can be a distance commensurate with the width of the surface then the field will diminish. When far away enough that the surface can be considered a point charge then it will be like a planet around the sun, following an ellipse or escaping completely.
So to answer the question in the thread's title, no, it isn't.
The problem is far from being simple. If you are looking for analitical equations of motion you will need to know the electric field in the space around your charged plate as a function of position. For an infinite plate the field is uniform in all space. For a finite plate is not. You may be able to approximate it with the field of an inifinite plate if the electron stays very close to the surface, compared with the plate size. If the electron moves over distances comparable with the size of the plate then you need to calculate the field numerically and then trace the motion of the electron also by numerical analysis.
On the other hand, if the electron is very far away from the plate, the field could be approximated with the field of a point charge.
But maybe you have two plates charged with opposte charges? When you say the the voltage of the plate is positive, this is relative to what? Is the electron moving between the plates of a capacitor?
Thank you nasu and haruspex!
How far does the electron travel is the question I want to answer. If a first pass (infinite plane solution) tells me that the electron is only microns (?) off the surface, maybe the simplification (infinite plane) was justified. If that initial solution result in an answer of cm or meters than a more robust treatment is required. Can you get me started on the math for the infinite plane solution?
In reality, this is all done in a vacuum chamber, with the chamber wall at ground. Maybe a better approach would be treating the problem as a parallel plate capacitor where one plate it represents the sample and the other plate is the represents the chamber walls? Can you get me started on the math for the parallel plate capacitor solution?
I am new to the forum. Should I move this discussion to another, more advanced, section?
No worries. I've gone ahead and moved the thread to the Classical Physics forum.
You will need more information about the system. To estimate how far it goes you need to know the gradient of the potential and not just the potential of the plate (which is an arbitrary value anyway). Or the charge density on the plate.
Can you give a bit more context ?
Can you describe those problems ?
If you express KE in eV, do you get something that is >> V , of the same order of magnitude as V , or << V ?
Equation of motion is ##\vec F = m\vec a## with ##\vec F = -e\vec E = e\vec\nabla V(x,y,z)## with ##V(x,y,z)## not the voltage of the plate but the electric potential field above the plate. See here for the integral
##m## is 9.109 ##\times 10^{-31}## kg
##e## is 1.602 ##\times 10^{-16}## C
Now, if I follow this thread, my estimate is that this doesn't help you very much. Right ? In that case we need more guidance from you to help us help you :smile:
Thanks Nasu. I am not sure what you mean about the gradient on the plate. Let's say the plate is a conductor, held at fixed potential (relative to ground) with an external power supply. Does that mean the gradient is zero?
Hi BvU - Thanks for your input.
I am interested in electrons in the range of 2-20 eV. The potential on the plane could range form 0 - 100 V.
No, the gradient menas how the potential changes in the space near the plate. The value of the potential at the plate by itself is irelevant. You can make it zero or any value you want. Important is the change in potential. If the electron starts with some kinetic energy KE, it will stop when
##KE=q\DeltaV=q(V_{final-V_{plate})##
How do I find the gradient?
Here is a picture if that helps.
I answered this case in post #4. What is the force on the electron?
@NB76 , let's take a step back. Before you find out the equations of motion, you need to know what problem you are solving. And the first question - which we still haven't answered - is whether the infinite plate approximation is valid or not.
Your electron starts with an initial kinetic energy T. It loses an energy qEh when it travels above the plane, where q is the electron charge, E is the electric field, and h is the height where it stops and starts its return. So h = T/qE. Now, if h is very small when compared to the size of the disk, you can treat it as an infinite plane. If h is very large when compared to the size of the disk, you can treat it as a point. In between, this gets very complicated.
So which is it?
This will depend on the details of your setup. You can't find it based on vague descriptions. You really need to specify the details of your setup. And eventually, what approximation will work, if any.
If it's an infinite plane, the field is uniform and the gradient of the potential is constant (and equal to the fieled, in magnitude).In this case, the motion is like a projectile motion. Same equations of motion,
The negative charge of the emitted electron will attract positive free charge on the plane and cause some "bunching" of positive charge on the plane in the area beneath the electron. So, the electric field experienced by the electron will not be uniform. The electron will be attracted back toward the plane with a greater force than if the charge on the plane remained uniform. This effect is stronger when the electron is near the plane. Maybe this effect can be handled by introducing a positive image charge of the electron.
So which is it?
Sorry for the delayed response.
Assume r is the radius of the charged disk form which the electron is ejected (in reality it is a more complicated shape).
I don't know the answer. I want to solve the infinite plane problem first because it seems like the easiest problem. If the solution dictates that the electron does not travel far above (h << r) the plane then I know it was a reasonable assumption.
If the electron travels a great distance from from the plane (h >> r) I would model the plane as a point charge?
If h~=r then I have a much more difficult problem that has a non-trivial solution.
Does this approach seem reasonable?
Could you give me a more detailed approach to starting this problem?
Looks good to me.
Remember that a uniformly charged sphere or spherical shell will produce the same field as a point charge, so that approximation might be usable for ##h\approx r## too.
Calculate the value of h at which the sheet and the point would produce the same field, then use the sheet approximation up to that distance.
I think @TSny's point about a changed distribution on the sheet is only relevant if the initial charge density and velocity are very low. (And certainly only if it is a conductor, which you have not mentioned.) E.g. if the sheet is an uncharged conductor then it is the same as an electron and a positron moving apart in mirror image trajectories.
Just to reiterate where I am in this problem. I know the field from a 2-D infinite plane is E = 2 k pi sigma. I don't know how to calculate sigma for an infinite plane held at a fixed voltage V. Can anyone assist with this?
With the field quantified, I expect the y-position to vary proportional to E t^2 (third equation, second term). Can I get some assistance with this second term?
haruspex said:
Looks good to me.
Thanks NB76 - could you help me put this into a formulaic form?
With the field quantified, I expect the y-position to vary proportional to E t^2 (third equation, second term in the diagram). Can I get some assistance with this second term?
Using the formula for the potential at distance x from the centre of a finite uniformly charged disc (https://phys.uri.edu/gerhard/PHY204/tsl82.pdf), obtain an approximation for small x. You should then be able to relate the potential at distance x to the potential at the centre of the disc.
I think I am asking a different question. I know the potential on the plane. I hook a power supply to the plane and set a voltage. I don't know the charge on the plane (sigma). How do I get from V (power supply) to sigma?
You can't connect the power supply just to the plane. You need to connect to something else the other terminal of the power supply. The charge on the plane will depend on the capacitance of the system plane + the something else.or the plane and the "ground".
The power supply will be referenced to ground (see drawing).
What I wrote gives you a way to relate the potential of the disc to its charge density.
The drawing is just a schetch of the principle. The actual charge desnity will depend on the actual sizes and shapes of the components. You cannot get it from general principles. It's the same idea as knowing the actual map of the potential in the system. If you know how thw potential changes from point to point you don't need the charge density.
… which we don't without doing something equivalent to what I suggested.
9K
  • · Replies 25 ·
  • · Replies 20 ·
  • · Replies 19 ·
9K
