Equilibrium constant varying with temperature but confused
The discussion revolves around calculating the equilibrium constant for the dissociation of the tri-iodide ion into iodine and iodide at different temperatures, specifically from 10 degrees C to 25 degrees C. Participants explore the use of the Van't Hoff equation and the implications of enthalpy in this context.
  • Homework-related
  • One participant suggests using the Van't Hoff equation to calculate the equilibrium constant at 25 degrees C but notes a lack of enthalpy data.
  • Another participant proposes using Hess's Law to find the change in enthalpy by looking up standard enthalpies of formation for the reactants and products.
  • A participant clarifies the correct product of the reaction as tri-iodide and expresses difficulty in finding the standard enthalpy of formation for iodine in aqueous state and tri-iodide.
  • Another participant counters that it is not necessary to look up the enthalpy of formation and suggests using experimental data with the Van't Hoff equation to derive the enthalpy of formation through plotting ln K versus 1/T.
Participants express differing views on the necessity of looking up enthalpy values, with some advocating for the use of experimental data while others suggest using standard enthalpies of formation. The discussion remains unresolved regarding the best approach to calculate the equilibrium constant.
Participants have not agreed on the availability or necessity of specific enthalpy data, and there are unresolved questions about the relationship between the equilibrium constant and temperature changes.
pyridine
OK. so i have a separation science lab report write up to do which involves the equilibrium of the tri-iodide ion dissociating into iodine and iodide. I know the concentrations at room temperature (which is very cold, about 10 degrees C, where i come from!), and thus the equilibrium constant. I then am asked to work out the equilibrium constant, K, at 25 degrees C. I know no other data, except a table of logK values for 0, 10, 20, 30, and 40 degrees C.
equilibrium for I3-:
I2+I- <---> I3-
I think you use the Van't Hoff equation, but i don't know the enthalpy...
Van't Hoff equation= Log(K1/K2) = enthalpy/R(1/T1-1/T2)
Many times you can calculate the change in enthalpy for a reaction by using Hess's Law. You would just need to look up the standard enthalpies of formation for the products and reactants (which can usually be found in the appendices of most general chemistry textbooks).
Also, I assume you mean the product is I3- or else the equation is not balanced.
Yep, the product is tri iodide...i just put the superscript in the wrong place...
It's complex because I can't find the standard enthalpy of formation of iodine in the aqueous state, or the standard enthalpy of formation of tri iodide.
Actually, you don't need to look up the enthalpy of formation. You can use your experimental data and the Van't Hoff equation to solve for the enthalpy of formation. If you plot ln K versus 1/T, the slope of the line will give you a value related to ΔH (I'm not going to specify how it's related, because you should derive the relationship yourself).
