Equilibrium solutions of a spherical pendulum
1 reply · 4K views · last reply
NobodyMinus
A spherical pendulum consists of bob of mass m attached to a massless rod of fixed length R. The end of the rod opposite the bob pivots freely (in two directions) about some fixed point.
For the conical pendulum (θ=constant) case, show that the conical angle is stable for θ< θ/2. That is, show that if θ=θ0+ε then oscillates about θ0 in harmonic motion. Plot the frequency of oscillation for angles 0<θ<∏/2. Comment on any interesting aspects of the curve.
g = 9.8, R = 1.8824, m = 1.96706
$$H=\frac{1}{2mR^2}\left(p_\theta^2 + \frac{1}{\sin^2\theta} p_\phi^2\right) + mgR(1-\cos\theta)$$
I don't really know how to type this out too well, but I took the derivative of H with respect to the canonical momentum in theta to get the first derivative of theta, then took the time derivative of that. this yielded
$$\ddot{\theta} = \frac{\dot{p}_\theta}{mR^2}$$
The hamiltonian to find the first derivative of pθ and plugging it in yielded
$$\ddot{\theta} = \frac{p_\phi^2}{m^2 R^4 \tan\theta\sin^2\theta}-\frac{g\sin\theta}{R}$$
and was from here unable to find an equilibrium solution
Places where pθ or p[itex]\phi[/itex] appear are meant to indicate pθ and p[itex]\phi[/itex] respectively, I just couldn't figure out how to do subscripts in latex
Moderator note: I reformatted your equations using LaTeX. Let me know if I made a mistake.
You guys are my last hope. Thanks!
hi, welcome to physicsforums!
You have done most of the hard work already. The question is asking about the behaviour of theta. So try to write the right-hand-side of your last equation in terms of just theta and constants.
Edit: ah, also, I guess you know that [itex]p_{\phi}[/itex] is a constant. But you will need to write it out explicitly, or finding an equilibrium solution (using the form the equation is currently in) is difficult (as you know already).
Edit again: no, sorry you don't need to write out [itex]p_{\phi}[/itex] explicitly. For some reason, I thought the equation in it's current form is bad. But it is fine in the form it is in now. So, the right-hand side is a function of theta only. And they want you to describe the behaviour close to [itex]\theta_0[/itex] How would you do this? (hint: it is effectively just a 1d problem now, so think of what you would do in a 1d problem).
