Amar.alchemy
- 78
Two identical, uniform beams weighing 260 N each are connected at one end by a fric-
tionless hinge. A light horizontal crossbar attached at the midpoints of the beams maintains an angle of 53.0° between the beams. The beams are suspended from the ceiling by vertical wires such that they form a "v," as shown in Fig. 11.56(see attached file) (a) What force does the crossbar exert on each beam?
\[\sum {{\tau _z} = 0} \]
If i apply the above formula for the system shown in the attached fig, then the forces - i) Tensions in the attached string ii)weight of the each rod iii)Force exerted by the crossbar on the beams iv)Force exerted by the hinges on the beam
All the forces mentioned above cancel out with each other because all the forces are equal in magnitude and produces torque in opposite directions.
Kindly give suggestions to solve this problem.
