Equivalent Bending Moment due to Impact Formula?
The discussion revolves around calculating the equivalent bending moment due to impact in a hydraulic vice grip system. Jamie initially used the formula for rotational kinetic energy, U=(1/2)*Im*w^2, but found an incorrect impact factor, G=0.17. After further analysis, Jamie successfully applied the formula U=PQt, which yielded better results. Key parameters include pressure (P=2500 psi), flow rate (Q=21 gpm), and the mass moment of inertia (Im=19.1 slug*ft*in).
  • Understanding of hydraulic systems and their components
  • Knowledge of rotational dynamics and energy equations
  • Familiarity with material properties, specifically Modulus of Elasticity (E)
  • Basic principles of bending moment and moment of inertia calculations
  • Study the application of U=PQt in hydraulic systems
  • Learn about the relationship between pressure, flow rate, and force in hydraulic cylinders
  • Explore advanced topics in rotational dynamics and energy conservation
  • Investigate methods for calculating the mass moment of inertia for complex shapes
Mechanical engineers, hydraulic system designers, and students studying dynamics and material mechanics will benefit from this discussion.
Jamie Gough
Hi guys and girls,
I've been working on this problem for a little while now but I'm not really getting the result that I want. This is what I have:
I have what is essentially a big pair of vice grips controlled by a hydraulic cylinder. The cylinder opens and closes both arms of the vice grips. The cylinder has a pressure, P, cross sectional area, A, and flow rate Q.
The arm rotates on a pin connection. The force from the cylinder on the arm is a distance, L away from the pin connection. The moment on the arm the cylinder produces is, M=P*A*L. The arm has a rectangular cross sectional area, a*b.
The rotational energy given to the arm by the cylinder is, U=(1/2)*Im*w^2, where I am is the mass moment of inertia of the arm about the pin, and w is the angular speed. w=(Q/A)*(1/L).
I know the elastic energy imparted to the arm is (1/2)*Me*theta, where theta is the angular deflection of the arm and Me is the equivalent moment produced by the impact.
So,
(1/2)*Im*w^2=(1/2)*Me*theta, where theta=Me*(theta_static/M), when theta_static is the deflection caused by M=P*A*L as a static load. We also know that M=(EI/L)*theta_static, where EI/L is the bending stiffness, and E is the Modulus of Elasticity, and I is the area moment of inertia.
Some rearranging I get:
Me= M*sqrt((Im*w^2*E*I)/(M^2*L)),
Where the impact factor, G=sqrt((Im*w^2*E*I)/(M^2*L))
I have:
Q=21 gpm,
P=2500 psi,
A=4.91 in^2,
L=10.4 in,
Im = 19.1 slug*ft*in,
a=5 in,
b=2 in,
E=30 Mpsi
I=(1/12)*a*b^3=3.3 in^4
Unfortunately, this leaves my impact factor, G=0.17. Of course the impact factor needs to be greater than or at least equal to unity. If anyone would kindly explain where I have gone wrong it would be very much appreciated.
Thank you kindly,
Jamie
Sorry but I cannot make any sense of this at all .
Please describe the construction and working of this device more completely and provide a drawing .
Thanks Nidum,
It's alright, I just managed to get it. I used U=PQt instead of the rotational kinetic energy and that worked much, much better.
  • · Replies 19 ·
  • · Replies 17 ·
