High School Error in Einstein's Biography on Twin Paradox?
The discussion centers on a perceived error in David Bodanis's biography "Einstein's Greatest Mistake," specifically regarding the twin paradox. The author suggests that an observer accelerating away from Earth sees life on Earth passing quickly, while an Earth observer sees the rocket traveler moving slowly, which raises questions about the clarity of his explanation. Participants clarify that both observers perceive each other in slow motion until one makes a U-turn, leading to different time experiences upon reunion. There is also a distinction made between what each observer sees versus their calculations based on their frames of reference. Overall, the conversation highlights confusion over terminology and the nuances of relativity as presented in popular science literature.
Vampke
Hi,
I am reading the biography "Einstein's greatest mistake" from David Bodanis.
On page 39 the author explains some of the consequences of relativity by referring to (although he doesn't mention it by name) the twin paradox. He explains that someone accelerating at high speed away from Earth would see life on Earth passing by very quickly, while someone on Earth observing the man in the rocket would see him moving through time very slowly.
However, I remember reading a popular science book by some or other physician that in both cases one observer would see the other in slow motion and that it is only when one of the two makes a U-turn to catch up with the other that they have had time passing at different rates when they meet up.
Which is the correct interpretation?
It seems like this author is confused. First, the word "accelerating" is unclear: is he talking about a rocket whose engine is constantly on? Or just about someone moving at high speed away from earth, but coasting, not firing a rocket engine to accelerate? I'm going to assume the latter, because that is usually how the twin paradox is presented, and it's a much simpler case to consider.
This is basically correct. For more details, I suggest the Usenet Physics FAQ article on the twin paradox:
http://math.ucr.edu/home/baez/physics/Relativity/SR/TwinParadox/twin_paradox.html
Note that there is a careful distinction to be drawn between what each observer actually sees (as in, the image in each one's telescope), vs. what they calculate for the coordinates of events in their respective frames of reference. The "Doppler Shift Analysis" page in the article discusses this.
I agree with Peter, if this is indeed how it is presented in the book, then the author is confused or not explaining himself very well. If it really was someone accelerating away from Earth and about what that person actually sees, the Earth would become more and more redshifted.
It is likely a language barrier problem, but just to point out that a "physician" is not the same thing as a "physicist".
Thanks for the explanation, which confirms what I thought.
The guy from the other book probably had 2 degrees ;)
Clearly I meant to say physicist
MOVING CLOCKS In this section, we show that clocks moving at high speeds run slowly. We construct a clock, called a light clock, using a stick of proper lenght ##L_0##, and two mirrors. The two mirrors face each other, and a pulse of light bounces back and forth betweem them. Each time the light pulse strikes one of the mirrors, say the lower mirror, the clock is said to tick. Between successive ticks the light pulse travels a distance ##2L_0## in the proper reference of frame of the clock...
  • · Replies 35 ·
  • · Replies 24 ·
  • · Replies 20 ·
  • · Replies 115 ·
9K
  • · Replies 20 ·
  • · Replies 21 ·
  • · Replies 70 ·
