Error Propagation: Explaining AB Calculation
This discussion focuses on error propagation in the context of calculating the product of two measurements, A and B, with associated uncertainties. The correct approach involves understanding that when multiplying two values, the relative errors add up. Specifically, for A = 100 ± 1% and B = 10 ± 1%, the product AB = 1000 ± 2% results from the formula d(AB)/AB = dA/A + dB/B. The discussion also introduces a more precise method for calculating error propagation using partial derivatives, leading to the formula δy = √(Σ|∂f/∂xi * δxi|²).
  • Understanding of basic statistics and error analysis
  • Familiarity with the concept of relative and absolute errors
  • Knowledge of partial derivatives in calculus
  • Basic proficiency in mathematical functions and their properties
  • Study the application of the error propagation formula δy = √(Σ|∂f/∂xi * δxi|²) in various contexts
  • Learn about the implications of relative error in scientific measurements
  • Explore the concept of differential calculus as it applies to error analysis
  • Investigate real-world examples of error propagation in physics and engineering
Students, researchers, and professionals in fields such as physics, engineering, and statistics who require a solid understanding of error propagation in measurements and calculations.
NotStine
Recently I came across an example for working out error propagation, and I'm having trouble following the steps:
A = 100 \pm 1%
B = 10 \pm 1%
AB = (100 \pm 1%).(10 \pm 1%)
=\left\{1000 \pm \left[\left(100.1\%\right) \pm \left(10.1\%\right)\right]\right\} // get confused here, how does this happen?
= 1000 \pm 1.1
= 998.9 - 1001.1
Can somebody please explain to me how the section I marked above appears.
Thank you.
Mathematics news on Phys.org
It doesn't happen- what you have is wrong. If A= 100\pm 1\%, so that A lies between 99 and 101, and B= 10\pm 1\%, so that B lies between 9.9 and 10.1, then AB lies between 99*9.9= 980.1 101*10.1= 1020.1. We could write those as 1000\pm (20\mp .1). 100*10= 1000 is not the midpoint of that interval: it is 1000+ 20+.1 and 1000- 20+ .1
We can think of it this way: the differential of AB is d(AB)= A(dB)+ B(dA). Dividing both sides by AB, dAB/(AB)= dA/A+ dB/B. In this problem dA/A= dB/B= .01 so approximately, dAB/AB= 2(.01)= 2%.
This is an example of an old mechanic's "rule of thumb": when two measurements add, the error of their sum is the sum of their errors; when two measurements multiply, the error of their product is the sum of their relative (or percentage) errors.
I see.
Thank you very much HallsofIvy. This was bugging me for a long time.
There is a general formula to calculate error propagation, which is statistically more accurate:
If you want to calculate the error of a function y=f(x_{1},x_{2},x_{3},...)
With x_{i} being measurements with given errors \delta x_{i}
Then the error of y is given by:
\delta y=\sqrt{\sum_{i=1}^{N}\left| \frac{\partial f}{\partial x_{i}}\delta x_{i}\right|^{2}}
F.e. here y=f(A,B)=AB
f_{A}(A,B)=B; f_{B}(A,B)=A
so \delta (AB)=\sqrt{B^{2}\delta A^{2}+A^{2}\delta B^{2}}
  • · Replies 18 ·
