Estimation of the volume of a solid.
The discussion focuses on estimating the volume of a solid with a base defined by the curves y = x + 3 and y = x² - 3, and bounded above by the surface z = x² + y. The intersection points of the base curves are identified at x = -2 (y = 1) and x = 3 (y = 6). The volume is calculated using rectangular cross-sections perpendicular to the x-axis, leading to the formulation of the area as the difference in y-values, resulting in the expression -x² + x + 6 for the base area. The integration of this area from x = -2 to x = 3 is necessary to find the total volume.
  • Understanding of Calculus, specifically integration techniques
  • Familiarity with functions and their intersections
  • Knowledge of rectangular cross-sections in volume estimation
  • Ability to manipulate algebraic expressions and equations
  • Study the method of calculating volumes using integration in Calculus
  • Learn about finding intersections of curves and their significance in volume problems
  • Explore the concept of cross-sections and their applications in solid geometry
  • Practice problems involving volume estimation of solids with varying boundaries
Students studying Calculus, particularly those focusing on volume estimation techniques, as well as educators seeking to enhance their teaching methods in solid geometry.
2dvh
Estimate the volume of the solid whose base is bounded by the graphs of y = x + 3 and
y = x2 − 3, and bounded by the surface z=x2+y from above, using the indicated rectangular cross sections taken perpendicular to the x-axis (figure is not the actual graph of the functions given above. It is solely a demonstration to help with the problem).
I've been trying to figure out a way to solve it for hours.
The only thing that I've done was figure out the area of the base, but i don't know if I am on the right track or not, seeing as the professor has not gone over this.
Did the problem really say "estimate"? It's a pretty straight forward Calculus problem to find the exact volume.
The base graphs y= x+ 3 and y= x^2- 3 (note that "x^2" is clearer than "x2") intersect where y= x+ 3= x^2-3 or x^2- x- 6= (x- 3)(x+ 2) or x= -2, y= 1 and x= 3, y= 6. Rectangular cross-sections perpendicular to the x-axis" means that the area is "height times base" where the base is the difference in y values, x+3-(x^2- 3)= -x^2+ x+ 6 and the height is [tex]z= x^2+ y[/tex]. The volume of a thin "slab" would be that area multiplied by thickness, dx. Integrate that from x= -2 to 3.
So then would the actual area end up being:
-x^4+x^3+6x^2-x^2y+xy+6y
Or am i wrong?
If it is right,would the volume be (125/12)*(2y+3)
  • · Replies 34 ·
