MHB Eulers phi function, orders, gcd
  • Thread starter Thread starter tda1201
    Function Gcd Phi
The discussion centers on proving that if a^k ≡ 1 (mod m) and a^l ≡ 1 (mod m), then a^d ≡ 1 (mod m) where d = gcd(k, l). It is clarified that it is not necessary for k to divide φ(m), with a counterexample provided. Participants suggest using the relationship kx + ly = d to approach the proof. Additionally, there is a recommendation to utilize LaTeX for clearer communication of mathematical expressions. The conversation emphasizes understanding the properties of orders and gcd in modular arithmetic.
tda1201
Let a, k , l , m e Z>1 and let a^k=1 (mod m) and a^l= 1 (mod m).
Let d=gcd(k,l)
Prove that a^d=1 (mod m).
I get already confused at the start: Is it true that k|phi(m) (Lagrange) but k can also be a multiple of the order of a (mod m) and then it can be the other way round.
Can anybody clarify this and give me a direction to start working? Thanks!
Mathematics news on Phys.org
Let d=gcd(k,l)
Hey tda120.
No. It is not necessary that $k|\phi(m)$. An easy counterexample is by taking $k=2\phi(m)$.
As for the question, use the fact that there exist integers $x$ and $y$ such that $kx+ly=d$.
I'd like to suggest that you check out our LaTeX forum and learn some basic LaTeX so that you will be able to post more readable questions.
Thank you, I think this helps me a lot!
You're right; I should start using LaTeX, but I'm still a bit shy at using it...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
