Evaluate Integral with Residue Theorem: Residue Theorem Homework
  • Thread starter Thread starter jjangub
    Residue Theorem
The discussion revolves around evaluating the integral \(\int_{0}^{2\pi} (cos^4\theta + sin^4\theta) d\theta\) using the Residue Theorem by converting it into a complex integral over the unit circle. Participants are exploring the application of complex analysis techniques, particularly focusing on the residue method and contour integration.
  • Mixed
  • Participants discuss converting trigonometric integrals into complex integrals, with one participant detailing their approach and results. Others point out potential algebraic mistakes and question the correctness of the contour used. There are inquiries about different methods for handling poles of varying orders and the application of the Cauchy Integral Theorem.
The discussion is ongoing, with participants providing feedback on each other's approaches and clarifying concepts related to residues and contour integration. Some participants express confusion about the methods and seek additional resources for better understanding.
Participants mention challenges with the Cauchy Integral and Residue Theorem, indicating a need for clarity on the conversion of integrals and the implications of different paths in the complex plane. There is also mention of a test approaching, which adds urgency to their inquiries.
jjangub
Evaluate \int_{0}^{2\pi} (cos^4\theta + sin^4\theta) d\theta by converting it to a complex integral over the unit circle and applying the Residue Theorem.
First, I switch (cos^4\theta + sin^4\theta) to 1-2cos^2\theta+2cos^4\theta (I will skip this one, this is not hard)
and then coverting to a complex integral by inputting cos\theta = (z+1/z)/2 and
multiply cos terms by 1/iz, so 1 - 1/iz(((-2)(z+1/z)/2)^2 + ((2)(z+1/z)/2)^4)
this is how prof. taught us...we have to use this formula
so if I do the work and make it simpler, then I get equal to
= (-z^8+2z^6+8iz^5+z^4+2z^2-1)/(8iz^5) in integral(-infinity to infinity)
= 2\pii \sum (Residue of f on upper half plane)
= 2\pii(-1/8i)Res0
= -\pii/4Res0
since Resa = h(z)/(z-a)^n = h^(n-1)(a)/(n-1!)
so in this case, Res0 = h^4(0)/(4!)
h(z) = z^8-2z^6-8iz^5-z^4-2z^2+1
if we do h^4(0), we get -12, so
= (-\pii/4)*(-12/4!) = \pi/8
I did it in this way and I got this answer.
Did I do anything wrong?
Thank you.
Two mistakes. First, you have an algebra mistake somewhere. Your integrand should be
\frac{z^8+6z^4+1}{8iz^5}
Second, your contour is wrong. You're using the substitution z=e. As θ runs from 0 to 2π, z moves along the unit circle. That should be your contour.
yes, I made a mistake.
Now, I got that equation. I know this quesetion sounds silly, but I am kind of lost on cauchy integral and residue theorem. so do we have different method for when we have 1 order of pole, 2 order of pole or higher, and for cos and sin?
Is there any good site which is well and easily organized about this?
And for this question, I got c0=e^(pi*i/5) and c1=3(pi*i/5)
but I can't get exact value of pi/5 for cos and sin...
maybe I did wrong...
Thank you.
The easiest, and probably the least error-prone, method is to expand the function as a Laurent series about each pole and then pick off the coefficient of the (z-z0)-1 term. In this problem, you have a (fifth-order) pole inside the contour at z=0, and the integrand is already a Laurent series about z=0:
-\frac{i}{8} z^{-5} -\frac{3i}{4} z^{-1} - \frac{i}{8} z^3
so the residue is -3i/4. This method, of course, requires proficiency in expanding functions as series, but once you acquire the skill, I think you'll find it's the easiest and quickest way to find the residue.
You can also find the residue of an n-th order pole using the formula
\frac{1}{(n-1)!} \lim_{z \to z_0} \frac{d^{n-1}}{dz^{n-1}} [(z-z_0)^n f(z)]
For this problem, this expression is pretty easy to evaluate, but when you have a more complicated function, you end up having to apply the product rule, chain rule, quotient rule, etc., and the algebra can easily become messy.
That said, either method is pretty straightforward conceptually. It's just a matter of doing the actual calculation correctly. That skill is something you'll develop with time and practice doing these problems.
Thank you.
Sorry, I'm not sure what c0 and c1 are.
maybe this will be the last question...I hope
so if I convert polar integral (with cos and sin) to complex integral, then
it changes from integral(zero to 2pi) to integral(negative infinity to positive infinity)?
or it works only if it is unit circle?
so i end up with Res(z=-3i/4)f = (2*pi*i)(-3i/4) = 3pi/2
I really appreciate your help...
Thank you so much!
The substitution you use to convert the integral is z=e. What path is traced out in the complex plane as θ runs from 0 to 2π?
Thank you so much!
so...path is 0 to infinity?
so I have to multiply by 1/2 to 3pi/2?
well...this cauchy and residue theorem parts are so confusing for me...
in class, prof gave us the easy example, so I understood, but the question for assignment and tests are hard...
I have test next week...how should I study cauchy and residue theorem?
just memorize theorem and do examples?
Thank you...
No. Where are you getting infinity from?
well, if i do it again, i got
z = e^i(0) = 1 and z = e^i(2pi) = cos(2pi) + isin(2pi) = 1
is this right?
You have z=e=cos θ+i sin θ. What path does this function map the interval [0,2π] onto?
