Evaluating Moment of Area Integral using Geometry
  • Thread starter Thread starter briteliner
    Area Moment
The discussion revolves around evaluating the moment of area integral, specifically the integral of (r^2 dA) using geometric methods. The original poster is attempting to understand the concept of the moment of area and how to set up the integral correctly for a triangular shape.
  • Exploratory, Conceptual clarification, Problem interpretation
  • Participants discuss the setup of the integral using polar coordinates and question the appropriateness of this approach for a triangle. There are inquiries about the specific shape of the triangle and the axis about which the moment of area is being evaluated. Some participants suggest using Cartesian coordinates instead.
The discussion is ongoing, with participants providing guidance on the shape and integration method. There is a lack of consensus on the correct approach, as some participants are exploring different interpretations of the problem and the necessary calculations.
There is uncertainty regarding the specific type of triangle being analyzed and the axis of evaluation. Participants have noted the need for clarity on these points to proceed effectively.
briteliner
the moment of area is integral (r^2 dA). With r measured from the origin, use geometry to evaluate this integral in both orders.
Ok so I set up the integral with dA=rdrd(theta) so with r from 0 to r and theta from 0 to pi/2. i ended up with pir^4/8 which i multiplied by for to account for each quadrant and ended up with (pir^4)/2.
is this correct? incorrect? why? i don't really get what the moment refers to. and also, if i am evaluating the correct integral. please help!
Hi briteliner! :smile:
(have a pi: π and an integral: ∫ and try using the X2 tag just above the Reply box :wink:)
(this is the second moment of area … it measures a body's resistance to bending stress perpendicular to a particular axis :wink:)
What shape are you trying to find the moment of area of, and about what axis? :confused:
a triangle, with x and y-axis i think
grrr! what shape of triangle? :rolleyes:
Anyway, you don't need r and θ for a triangle
just use dxdy as usual …
show us what you get. :smile:
if b is the height and a is the width, i get (3(b^3)(x^3))/(y^3)
(try using the X2 tag just above the Reply box :wink:)
How can x and y be in the answer?
It should just have a and b.
(btw, is this a right-angled triangle? and you still haven't said what the axis is)
Anyway, show us your full calculations next time. :smile:
You're in Nearing's class, aren't you? lol
Pic is a right triangle with vertices at (0,0), (a,0), and (a,b).
Recall how to change the integrand so that you can integrate properly. (How is r related to x and y if you choose to integrate with respect to x & y?)
  • · Replies 17 ·
  • · Replies 23 ·
