Evaluating the charge distribution integral with binomial expansion
26 replies · 3K views
binbagsss
part b of below
[/B]
##(1+x)^{1/2}=1+\frac{1}{2}x-\frac{x^{2}}{8}+...##
[/B]
##\int\limits^{\Lambda}_{-\Lambda} \frac{dy}{\sqrt{r^2+y^2}}=log(\lambda+\sqrt{\lambda^2+r^2}) - log(-\lambda+\sqrt{\lambda^2+r^2}) ##
##= log(\lambda(1+\sqrt{1+\frac{r^2}{\lambda^2}}))-log(\lambda(-1+\sqrt{1+\frac{r^2}{\lambda^2}}) )##
## \approx log(\lambda(1+1+\frac{r^2}{2\lambda^2}-\frac{r^4}{8\lambda^4}) )- log(\lambda(\frac{r^2}{2\lambda^2}-\frac{r^4}{8\lambda^4}))##
which is off track... thanks
Orodruin said:
Hint: ##\log(x) + \log(y) = \log(xy)##
huh? i used that already. oh my expansion need to use a taylor to get the right order
ok ,
so do i need to consider the bit I am applying the logarithm to, expand this out and then apply the logarithm.
i.e. so i need to consider ##\frac{\Lambda(1+\Lambda(1+\frac{r^2}{\Lambda^2})}{\Lambda(-1+\Lambda(1+\frac{r^2}{\Lambda^2})}=(1+\Lambda(1+\frac{r^2}{\Lambda^2})(-1+\Lambda(1+\frac{r^2}{\Lambda^2}))^{-1}##, and get this to first order in ## x##but now do I expand out the square roots first in both terms, using ## (1+x^2)^{1/2} \approx 1 + x^2/2 +... ## and then use ##(1+x)^{-1} \approx... ## or do I do it the other way around?
how do I know which is correct?
Not shown in the OP, so how can I know if you used it or not?
I suggest that you use it in the other direction. Expanding the square roots is fine.
apologies yes you did- how do you know however, that you are doing something wrong if you use the way I intially tried? since it's an identity I don't understand why you would have to select and how the other could be wrong? thanks
Orodruin said:
I don't understand, what do you think is wrong?
you said hint
as in me trying to use ##log(x)+log(y) ## and expand the expressions ##x## and ##y## is not correct but rather I need to consider expanding ##x/y## , how can that be when it is just an identity?
was this not the idea behind your post 2
I did not say it was not correct. I said there is an easy way to do it and a hard way to do it. The easy way to do it is to expand everything on the form log(xy) to log(x)+log(y).
I would suggest that before using the expansion you should use the log identity mentioned by Orodruin. This will cancel the first ##\lambda## terms, although I would find it more straight foreword to use the quotient rule to do this. Once you have everything as a single fraction, expand the numerator and simplify the first term. What does that give you?
Again, as stated in #8, this is the long way around. I strongly advise against going to a single log expression.
wait I'm confused again, i did the start the expansion with two log terms not a single one?
Yes, and going to a single one is going to make it more complicated. The more straightforward way to do it is to further expand the logs that you have.
is your post 2/4 not telling me to do the opposite of what I started?
So you want me to include higher order terms to what I did in my OP:
## \approx log(\lambda(1+1+\frac{r^2}{2\lambda^2}-\frac{r^4}{8\lambda^4}) )- log(\lambda(\frac{r^2}{2\lambda^2}-\frac{r^4}{8\lambda^4}))##?
Orodruin said:
No, I want you to expand those logs.
oh right, using (1+x) \approx ...
but the final expression has log? this would get rid of them?
He's saying use: log(ab)-log(ac) = log(a)+log(b)-log(a)-log(c)
ok so I now have
##log \Lambda + log (2+ \frac{r^2}{2\Lambda^2}) - log \Lambda - log(\frac{r^2}{2\Lambda^2})##
so the \lambda term cancels, as you can see obviously by considering the log as a single expression initially, but I am stil far from the answer- of the wrong order in ##x=\frac{r}{\Lambda}##
Not only that. There are also the manipulations that will leave only logs on the sought form, logs on the form log(1+x) that can be series expanded, and constant logs.
binbagsss said:
ok so I now have
Use log(xy) = log(x)+log(y) more times!
hmmm something like ## log (\frac{r}{\sqrt{2}\Lambda}(\frac{2\sqrt{2}r}{\Lambda}+\frac{r}{\sqrt{2}\Lambda}))-log(\frac{r}{\sqrt{2}\Lambda}\frac{r}{\sqrt{2}\Lambda})##
##log(\frac{r}{\sqrt{2}\Lambda})+log(\frac{2\sqrt{2}r}{\Lambda}+\frac{r}{\sqrt{2}\Lambda}) -log(\frac{r}{\sqrt{2}\Lambda})-log(\frac{r}{\sqrt{2}\Lambda})
= log(\frac{2\sqrt{2}r}{\Lambda}+\frac{r}{\sqrt{2}\Lambda})-log(\frac{r}{\sqrt{2}\Lambda})## ?
what should I have done here instead?
No, you are just overcomplicating things now. Just keep expanding from what you had.
Forgive me for being off-topic, but is it not easier to just use trigonometric substitution: ##y=r⋅tan(\theta)## and prove that the integral diverges on the interval ##(-\frac{\pi}{2},\frac{\pi}{2})##?
The OP is working on part (b).
there's nothing to talk to unless you factorise something?
And you already had perfectly fine factors. There was no need to overcomplicate it. Why you would start introducing factors of ##\sqrt 2## I really cannot understand. Just use the rule and in the logs where you have two terms factor out the leading one (as it is, not with any weird factors of ##\sqrt 2## - how else are you going to get a factor 1+x?).
ok
, but why would you want to seek the form log (1+x) when we don't want to expand things since we want log (x) ... or that's ok for the O(x^2) terms I guesss, where we have ##x = \frac{r}{\lambda}##?
So how about:## log 2 + log (1+x^2) - log ( \frac{x^2}{2}) = 2 log 2 + log(1+x') - log(x') ##
but I'm still stuck with ## log(x') ## , where ## x'=\frac{r^2}{\lambda^2}##, the log 2 is a constant as required, the ##log(1+x')##, once expanded, will take the form of constant terms plus ##O(\frac{r^2}{\lambda^2}) ##so that's fine, its just the log(x') term..?
Again, use ##\log(ab) = \log(a) + \log(b)##.
