Even Functions, Symmetry, Inverse Functions
confusedatmath
Can someone explain why the answer is D
a < 0 because it finishes downwards
e < O because the y-intercept is in the negatives.
b, & d = zero (but i don't get this)
c is supposedly > 0 (nor do i get this)
According to the solutions the graph is an even function, and symmetrical about the y-axis/x-axis. I haven't studied this, can someone please explain for values b,d,c.
  • Graph of a quartic curve y = ax^4 + bx^3 + cx^2 + dx + e, opening downwards, with two peaks on either side of the y-axis and a lower dip crossing the y-axis below the x-axis.
Looking at the graph, we can see it is reflected across the $y$-axis, meaning it is an even function, which means:
$$y(-x)=y(x)$$
This means the coefficients of the terms having an odd exponent on $x$ must be zero, i.e.:
$$b=d=0$$
This leaves us with:
$$y(x)=ax^4+cx^2+e$$
Now, we see that:
$$y(0)=e<0$$
We also see that as $x\to\pm\infty$ we have $$y(x)\to-\infty$$. This means the dominant term, that is, $ax^4\to-\infty$ which implies $a<0$. But in order to have $y(x)>0$ on the two shown intervals, we must have $0<c$.
is there an equation for symmetry in x-axis?
A function, by definition, cannot be symmetric across the $x$-axis. For any given input, a function can only have one output.
Hello, confusedatmath!
We have: .[tex]y \:=\:ax^4 + bx^3 + cx^2 + dx + e[/tex]
The graph is symmetric to the y-axis.
On the right, we have two x-intercepts, [tex]p[/tex] and [tex]q.[/tex]
On the left, we have two x-intercepts, [tex]\text{-}p[/tex] and [tex]\text{-}q.[/tex]
The function has the form:
. . [tex](x-p)(x+p)(x-q)(x+q) \:=\:x^4 - (p^2+q^2)x^2 + p^2q^2[/tex]
Since [tex]a[/tex] is negative, we have:
. . [tex]y \:=\:-\left[x^4-(p^2+q^2)x^2 + p^2q^2\right][/tex]
. . [tex]y \:=\:-x^4 + (p^2+q^2)x^2 - p^2q^2[/tex][tex]\begin{array}{cc}\text{Therefore:} & a\text{ neg.} \\ & b = 0 \\ & c\text{ pos.} \\ & d = 0 \\ & e\text{ neg.} \end{array}[/tex]
wow mindblown. :O that was such a cool way of solving it! THANK YOU (Inlove)
A non-function relation such as [tex]x^2+ y^2= 1[/tex] of [tex]x^2+ (y- 2)^2= 1[/tex], may be "symmetric about the x-axis". Just as the test for "symmetry about the y-axis" is f(x)= f(-x) (so that replacing x with -x does not change the equation) so the test for "symmetry about the x-axis" is that replacing y with -y does not change the equation.
Because [tex](-a)^2= a^2[/tex], in the first example above, [tex]x^2+ (-y)^2= x^2+ y^2= 1[/tex], the same as the original equation, so that is "symmetric about the x-axis". (Its graph is a circle about the origin.)
The second would give [tex]x^2+ (-y- 2)^2= x^2+ (-(y+ 1))^2= x^2+ (y+1)^2= 1[/tex] which is NOT the same as the original. The graph of [tex]x^2+ (y- 2)^2= 1[/tex] is a circle with center at (0, 2) so is symmetric about y= 2, NOT y= 0 which is the x-axis.
