Exactly how do i control the fall of a falling object? (for power generation)
The discussion revolves around the concept of using a falling object, specifically a 100kg sandbag, to generate electricity in a vertical shaft approximately 100 meters deep. Participants explore the calculations of potential energy and power generation, the mechanics of controlling the fall, and the efficiency of the system, including the role of generators and load types.
  • One participant calculates potential energy output as either 98 kW for 1 second or approximately 27 watts for 1 hour, while another corrects this to 98 kW and 27 watts respectively, indicating a misunderstanding in the initial calculation.
  • Some participants suggest that the generator could regulate the fall of the weight depending on the load connected, while others emphasize the need for control circuitry to achieve a slow fall.
  • There is a discussion about the nature of energy conversion, with some arguing that kinetic energy is converted into electricity, while others assert that potential energy is harnessed during the fall.
  • A mechanism like a rocking ratchet or escapement is proposed as a means to control the descent of the weight slowly.
  • One participant mentions that the maximum energy obtainable per cycle is 98 kJ, and the time taken for the cycle will influence the power output.
  • Concerns are raised about the efficiency of the system, with estimates of 75-90% efficiency discussed, and the impact of friction and other losses on energy output.
  • There is a suggestion that using a battery to store energy might be a more effective approach than relying solely on the falling weight for energy generation.
Participants do not reach a consensus on the best method for controlling the fall of the weight or the most efficient way to generate electricity. Multiple competing views on energy conversion and system design remain present throughout the discussion.
Participants express uncertainty regarding the specifics of generator selection and the relationship between load and fall rate. The discussion also highlights the complexity of energy transfer and the potential inefficiencies involved in the proposed system.
Individuals interested in energy generation, mechanical systems, and the physics of potential and kinetic energy may find this discussion relevant.
Shepton
Hi!
So i have been having this discussion with a friend. we have an old shaft going down about 100meters and we want to tie a 100kg sand bag and use it to generate electricity as it falls. (we will simply pull it back up)
if my understanding is right, then:
i can either generate 980kw for 1 second OR aprox 200watts for 1 hour. am i correct?
if i am correct, then how exactly do i make the weight fall over 1 hour? also, i know that the figure of 980kw does not take into account efficency loss so can i get please get some advice on this as well? what will be the true output once friction and all that is taken into account?
Welcome to PF!
Er...I'm getting 98 kW for 1 second or 27 watts for an hour...could you post your math?
Well, it is connected to a generator, so the generator may regulate the fall itself depending on the type of load you connect to it. Otherwise, you'd need some control circuitry.
Friction and other inefficiencies don't have to be a very big factor for such a simple system. You could probably do 75-90% total efficiency.
The power calcs you have done are averages only, you will get more power out at the end of the fall.
I don't think you can get it to fall in less than about 4.5s without throwing it... but the reasoning (not the arithmetic) is fine ... there is a maximum energy that you can get out of such a set-up. Not all this energy will get turned into electricity - how much should depend more on the generator you use than the rest of the setup... but I haven't seen your materials.
In practice - you convert kinetic energy into electricity - not gravitational PE ... this is important.
If you converted all the kinetic energy into electricity - the mass would end with zero kinetic energy and stop.
A stationary mass cannot turn your generator...
If you want the mass to fall slowly, then you need a rocking ratchet type mechanism like in a clock... there's a special name for these that keep forgetting. You can also release the mass a little at a time of course, and, whatever you do, the generator itself will slow the mass.
Thank you for the welcom! you are correct russ, the figures are 98 and 27 respectively. i hit an extra 0.
can you please give me a name of a generator that would regulate the fall? will this mean that if i have a 27watt bulb plugged in, the weight would fall over an hour and if i had a 13watt bulb plugged in, the weight would fall over 2 hours? or did i misunderstand?
Simon, at the moment, the only materials i have is a sandbag in which i can fill a 100kg of sand. i think the shaft used to be a well because it has a pully with bucket tied to it, something like this:
the plan is to replace the bucket with the 100kg sand bag and allow it to fall over a period of hour or 2 hour. the hole is about 6-8 meters in diameter so i am sure i can add some more sand bags to get more watts out. but i want to try it with one bag first.
Well, sorta. Falling at constant speed yields constant power output -- at least for the realistic slow falls. Trying to get the energy quickly is problematic because you have to let the weight accelerate and then absorb the energy at the end of the fall (as you were saying) and there is a minimum time...
Yes, that's a good point: when trying to get the energy in a short time, you have to deal with the acceleration due to gravity issue. At the minimum time of 4.5 seconds, that's 100% acceleration, which means you get no energy output, just an impact with the bottom of the well. As you lengthen the time, you hyperbolically approach the theoretical maximum energy extraction.
No, that's mostly wrong. Except in the very fast fall case, you are harnessing potential energy, not kinetic energy. Harnessing kinetic energy means you are slowing something down whereas harnessing potential energy means applying a constant force over a distance. A lot of hydroelectric dams work each way.
[edit: softened the last part] Examples: Hoover dam is a Pelton (kinetic energy) turbine, while the Three Gorges Dam is a potential energy type Francis turbine. Most dams use Francis turbines. Pelton turbines work best with high head (Hoover Dam: 590 feet, Three Gorges Dam: 264 feet).
I'm a little thin on the electrical part, so others might do better, but have a look here for a start:
http://www.wikihow.com/Produce-Electricity-from-a-DC-Motor
Basically, if you have a purely resistive load (an incandescent bulb?) and the generator is matched to it well, essentially what happens is the voltage increases as the generator spins faster. Then, the higher the voltage, the brighter the light bulb gets and more energy it uses. As it does this, it increases the torque on the generator, which stops the acceleration, resulting in a constant-speed fall of your weight.
The generator does slow something... but that's mostly splitting hairs. I mean maybe there is some conventional terminology that makes that definition. What I mean is that an electric generator that is likely to be useful here needs to move in order to work.
Since the weight gets hauled up by hand each time, it seems this is something that should be experimented with.
Escapement
The only sure thing is that you will produce no more than 98 kJ of energy per cycle (the weight going up once and down once).
Then, the time it takes to complete the cycle will dictate the power you can get out of the system in the long run.
The best thing you could do is to charge a battery, no matter how much time it takes to do it. How fast you discharge the battery is up to you. If your power demand is greater than the power of your generator, you will simply have some intermittent down time.
The problem with your concept is that your using an unnecessary energy transfer: watching the weight fall. No matter how you will get the weight up, you could use that energy to directly turn your generator. Storing it in a mass under potential energy just to release it somewhere else is a waste of time and a source for losses.
I believe that the term you're looking for is "escapement".
By the bye, Shipton... that picture of yours is the most vivid "Hitchiker's Guide" flash that I've had without tequila being involved.
edit: Sorry Dr. Claude. I just now saw your response.
10K
  • · Replies 41 ·
  • · Replies 26 ·
10K
