Example of x0 in the kinematic equation for displacement
In the kinematic equation x = x0 + v0 * t + 0.5 * a * t^2, x0 represents the initial position of an object and can take any value based on the chosen coordinate system. An example provided involves dropping an object from a height of 5 meters, where x0 equals 5 meters and the initial velocity v0 is zero. The discussion highlights that both x and x0 can be non-zero in horizontal motion by selecting an appropriate origin, such as starting a particle 5 meters from the origin with an initial velocity of 5 meters per second. Ultimately, the value of x0 depends on the reference point chosen for the coordinate system. Understanding these concepts is crucial for solving kinematic problems effectively.
e-zero
In the kinematic equation x = x0 + v0 * t + .5 * a * t^2, can someone give me an example in which x0 has a value that is not zero?
Hi e-zero! ##x_{0}## is just the initial position of the test particle that you are looking at the trajectory of under constant acceleration; similarly ##v_{0}## is just the initial velocity of the trajectory. You can choose them to be whatever you want them to be. I can for example drop my object from a height of 5 meters from the ground, starting at rest, in which case ##x_{0} = 5 \text{m}## , ##v_{0} = 0 \text{m /s}## , and (ignoring air resistance) the equations of motion become ##x(t) = 5 \text{m} - \frac{1}{2}gt^{2}##. Hope that helps friend!
Ok, is there an example where both x and x0 are both not zero?
##x(t)## is a function of time so it will change its value at every instant of time. In the example I gave above, ##x(t)## is the height of the particle from the ground so it will be non-zero up until the first time the particle hits the ground.
Can you give an example that does not involve vertical, but horizontal motion in which x and x0 are both not zero?
Sure! Choose an origin and take a particle located 5 meters horizontally from that origin and give it an initial kick of 5 meters per second in the horizontal direction.
Ok. I was just confusing myself. It all depends on the question if you should take x0 to be zero or not.
Indeed! Good luck with your studies friend :)
Thanks
Not really. It depends on where you want the origin of your system of coordinates to be. In WBN's example, he chose the ground as origin. That's why x_0 in his case was 5m. For the same example he could have chosen its origin 5 meters above the ground, in which case x_0 would have been 0.
Ok, I see.
  • · Replies 49 ·
  • · Replies 20 ·
  • · Replies 17 ·
