Excel help in making a document to calculate Cp of Air
  • Thread starter Thread starter StephenQueen
    Air Excel
An Excel spreadsheet is being created to calculate the specific heat capacity (Cp) of air based on temperature inputs ranging from 200 to 2250. The user encountered a division by zero error when entering exact temperature values due to the formula selecting the same values for temperature. They are exploring the use of an IF statement to adjust the upper temperature value but faced complications with too many arguments. Suggestions include simplifying the IF statement and using a method to automatically select the next sequential cell. The user believes they may have resolved the issue by adjusting the upper check to always add 1 to the temperature input.
StephenQueen
using the table of values supplied (a pdf document), construct an excel spreadsheet wherein a value can be input from 200-2250 and output will be air's specific heat capacity at that temperature.
Cp= H2-H1/T2-T1
I have completed most things, I am just having issue where an exact value is entered on the temperature table, ie 200 has a value for H, and as such my formula input in both cells which is designed to essentially round down or up from the value selects the same values for Temperature and thus divides by zero.
I am currently attempting to input an If statement into the cell containing the upper (T2) value, but containing too many arguments.
This is the statement i have been using to calculate temperature for the upper:
=SMALL($D$18:$D$138,COUNTIF($D$18:$D$138,"<"&M21)+1)
inputting an if function I thought of but it ended up containing too many arguments (essentially if A1=A2 then above formula acts as if M21 was added with +1 to its cell).
So is there a way to simplify?
Or should i make cell 2 conditional upon cell 1 and try and make it select the next sequential cell automatically?
How do I do that?
Any and all help is appreciated.
Hey StephenQueen and welcome to the forums.
The simplest If statement is just =IF(statement,true-value,false-value). You can nest the if statements within each other to do more complex statements.
For example =IF(A1>B1,1,0) would return 1 if A1>B1 and 0 otherwise.
Can you outline in the simplest manner what your conditions are? If you can provide really simple pseudo code and all the checks you need to do, then we can give more specific advice.
My conditions are to check for the closest upper value within an array of cells compared with the 'temperature' input, and correspond with the output being that closest temperature.
What I'm trying to do is have the cell check if its value is the same as that of another, and if so, to change its output to the next highest integer.
I think I may have solved my problem though- I don't think i may need the if operator now, just changing the upper check so that it always adds 1 to the value of temperature. Seeing as it will always tend towards that value anyway, it changes little.
I think i did it.
  • · Replies 16 ·
