Existance of particles in potential extrema
Particles can theoretically exist at a potential's extremum with zero velocity if they are placed there with that condition. The discussion highlights that while stationary points can be solutions, their stability depends on the nature of the potential; local minima are stable, while maxima are unstable. The teacher's assertion may relate to quantum mechanics, where the Heisenberg uncertainty principle implies fluctuations around classical solutions. The analogy of a ball on a hilltop versus a valley illustrates the stability of these points. The conversation also raises interest in exploring the time it takes for a particle to reach such an extremum.
Ourives
First time poster so I apologize any problems with location or content. By the way, you guys are awesome.
Just some context: last semester I had a theoretical mechanics class and the teacher said, while teaching us about the Lagrangian formulation, that particles cannot, ever, reach a potential's extremum and stay there (zero velocity). I was very curious at the time but never actually thought about tackling the problem. So today it popped in my head while cooking lunch.
I went at the problem in a uni-dimensional way, starting by defining a general potential with an extremum, approximating it, at that point, by a Taylor series to terms of second order and seeing what it meant in terms of equations of motion via the Lagrangian formulation:
{\frac{dV}{dx}|_a=0}
{V(x)\approx{V(a)+\frac{dV}{dx}|_a (x-a)+\frac{1}{2}\frac{d^2 V}{dx^2}|_ a (x-a)^2}}
{L=\frac{m\dot{x}^2}{2}-\frac{1}{2}\frac{d^2 V}{dx^2}|_ a (x-a)^2}
(the first and second terms on the right hand side of the potential are, respectively, null and a constant that does not influence the equation of motion)
This leads to, using the Euler-Lagrange equations, to the following equation of motion:
{m\ddot{x}+\xi (x-a)=0}
This leads to:
{x=Ae^{-i\alpha t}+Be^{i\alpha t}+a}
Applying the conditions of zero velocity at point "a" at a certain time one gets:
{x=a}
This shows that the only possible way for a particle to exist in a potential extremum with zero velocity is if it is "put" there with zero velocity.
I now want to tackle the problem of how much time it takes for the particle to reach such an extrema. Any ideas?
Thanks in advance!
Of course you are right. At stationary points of the potential, i.e, where \partial_i V(q)=0, there is always a solution, where the particle stays at this place at rest. I don't know what your teacher meant by telling the opposite.
Of course, another question is the stability of this stationary solution. The stationary solution is only stable against small perturbations when there is a local minimum at the stationary point, i.e., the Hesse matrix of the potential, \partial_i \partial_j V(q), must be positive definite at the point at the stationary point. If its negative definite, it's unstable against small perturbations in any direction. If it's indefinite, you have a saddle point, and then the solution is stable for perturbations in some directions and unstable for such in other directions.
Perhaps your teacher has made a remark on quantum theory, where the Heisenberg uncertainty relation tells you that there are necessarily always fluctuations around the classical stationary solution, but that's another story.
The analogy of a ball being put on a hilltop or in a valley certainly applies here. I think what he meant is that such solution never exists in nature, not even classically. On a hilltop it's easy to see why (it's unstable) but in a valley small perturbations will always produce some tiny oscillation that destroys our stationary solution.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
