Expectation value of an angular momentum with a complex exponent
Calculating the expectation value of angular momentum with a complex exponent can be challenging due to the presence of exponential terms. The discussion highlights the use of Euler's formula and commutator relations, but participants struggle with terms like exp(L_z). A breakthrough occurs when one suggests expanding the expression using a Taylor series, leading to a simplification. By recognizing that L_z can be expressed in terms of its eigenvalues, the expectation value can be reformulated into a more manageable form. This approach effectively resolves the initial difficulties encountered in the calculation.
isochore
Find ## \langle l, m \vert \exp((a+ bi)L_z) \vert l, m \rangle ##
## L_z \vert l, m \rangle = \hbar m \vert l, m \rangle ##
## [L_x, L_y] = i \hbar L_z ##
I am struggling to figure out how to calculate the expectation value because I am finding it hard to do something with the exponential. I tried using Euler's formula and some commutator relations, but I am always left with some term like ##\exp(L_z)## that I am not sure how to get rid of.
Dr Transport said:
Taylor series for the exponent...
Ahh, not sure why I did not think of that...
So you can expand starting with the original expression ## \langle l, m \vert \exp((a+bi)L_z) \vert l, m \rangle ##, then since ##L_z = \hbar m \vert l, m \rangle## you can simply compress back into something like ## \exp (\hbar m (a+bi)) ##?
