How to Experimentally Measure the MTF of a Lens?
This discussion focuses on experimentally measuring the Contrast Transfer Function (CTF) of a lens using a specific setup involving a light source, target, lens, and camera. The recommended method includes printing a series of black-and-white bars with equal widths and measuring the normalized contrast of images taken at various line pair spacings. An alternative method involves imaging a black-white transition and applying a Fast Fourier Transform (FFT) to the pixel data to derive the CTF. For in-depth understanding, the reference to Vollmerhausen and Driggers' "Analysis of Sampled Imaging Systems" is essential.
  • Understanding of optical transfer functions and contrast transfer functions
  • Familiarity with Fast Fourier Transform (FFT) techniques
  • Knowledge of lens aberrations, particularly astigmatism
  • Experience in experimental photography and image analysis
  • Research methods for measuring optical transfer functions in sampled imaging systems
  • Learn about the implications of aperture settings on lens performance
  • Explore the relationship between point spread function and contrast transfer function
  • Study the techniques for analyzing aberrations in optical systems
Optical engineers, photographers, and researchers interested in lens performance evaluation and image quality analysis.
Gifty01
TL;DR
MTF
Hi all, I will like to measure the MTF of a lens experimentally. In the set-up, I have my light - target - lens - camera. When my object (target) is at the focus of the lens, I took an image.
My question now is, to I move my object across one pixel or few pixels or to move my object across several pixels ( If I move across several pixels, I obtain a defocused image) Therefore, what is the best way to do this experimentally. Thanks in advance
Astronomy news on Phys.org
Not to come off as totally pedantic, but measuring the MTF is really hard and time-consuming because it's a complex-valued quantity. What you actually want to measure isn't even the the modulus of the MTF (the optical transfer function), but the "contrast transfer function" (CTF) because you have a sampled imaging system and not a continuous detector like film.
Measuring the CTF is fairly straightforward- print out a set of black-and-white bars, with the separation distance equal to 2x the bar width (so the black and white sections have equal width). Do this for a range of "line pair" spacings. At some point, you will need to convert the actual line pair spacing (say, 0.5 lp/mm) to line pairs/pixel, but that conversion will depend on your setup.
Then, simply image the target- the (normalized) contrast of your image as a function of line pair spacing is equal to the CTF. You can do this over the image area to compare the optical performance near the optical axis to the optical performance at the edge of the frame, determine the effect of stopping down the aperture, determine aberrations like astigmatism (by rotating the bars 90 degrees), etc. etc.
There's a clever alternative method you can use with a single image, taking advantage of the relations between the transfer function and point spread function, edge spread function, and line spread function- simply image an abrupt black-white transition and perform an FFT on the image pixel data normal to the transition. The FFT of that data is the CTF.
For hard-core details that covers sampled imaging systems including aberrations like aliasing, I recommend Vollmerhausen and Driggers "Analysis of Sampled Imaging Systems" (SPIE press).
Does that help?
  • · Replies 226 ·
16K
  • · Replies 40 ·
  • · Replies 26 ·
