Explaining (ir)reversibility with S.M.
  • Thread starter Thread starter nonequilibrium
The discussion explores the concept of (ir)reversibility in thermodynamics and statistical mechanics, focusing on a gas system with a piston. It highlights that compressing the piston quasi-statically results in negligible entropy change, while rapid compression leads to significant entropy increase. The conversation questions how to intuitively understand entropy (S) in these scenarios, particularly regarding the relationship between entropy and the number of microstates (omega) in statistical mechanics. It emphasizes the need to classify processes as reversible or irreversible to assess their entropy changes accurately. Ultimately, the discussion seeks to clarify the justification for considering quasi-static processes as reversible in the context of physics.
nonequilibrium
Goodday,
Everyone knows: imagine the isolated system consisting of a reservoir and a box with a gas and one of its sides is a piston. If we (inside the system) compress the piston quasi-statically, the entropy increase of the isolated system is zero (or negligible if we do it slowly enough). If we on the other hand charge and bump into the piston and compress it all at once, the entropy change is considerable.
Now I was wondering how I could imagine this quantity S in this situation and more specifically: try to explain it (intuitively).
So I was thinking of doing it with classical thermodynamics with the use of Clausius' relation, but then your argument depends on you classifying it as a reversible or irreversible, which is kind of what you are trying to explain.
If we look at Statistical Mechanics, I see no connection at all with (ir)reversibility. If we denote the entropy of the isolated system as S, then S = k log(omega). Now is there anything in the theory of S.M. that predicts (and maybe even explains...) that in the first scenario, omega is constant, and in the latter, omega grows?
Irreversibility is a statistical statement of probabilities being sufficiently high. Where is the problem?
It's worth thinking about what the actual question is.
Both thermodynamics and statmech say that there are reversible and irreversible processes. You need to know the exact process to judge which one it is. So what is the question now?
Maybe a better question is: Whatever you see as a quasi-static process (slow?), how does physics justify that it is reversible?
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
Thread 'A scenario of non-uniform circular motion'
(All the needed diagrams are posted below) My friend came up with the following scenario. Imagine a fixed point and a perfectly rigid rod of a certain length extending radially outwards from this fixed point(it is attached to the fixed point). To the free end of the fixed rod, an object is present and it is capable of changing it's speed(by thruster say or any convenient method. And ignore any resistance). It starts with a certain speed but say it's speed continuously increases as it goes...
