Explaining sinh and cosh graphically
  • Thread starter Thread starter Seung Tai Kang
3 replies · 2K views
Seung Tai Kang
tanh x is 12/13 . Then cosh x is 12/5 and sinh is 13/5. This can be found algebraically by finding x.
tanh x= sinh x/cosh x
The answer can be found algebraically by finding x. tanh x= sinh x /cosh x.
tanh(x) =
sinh(x) / cosh(x) =
((1/2) * (e^(x) - e^(-x))) / ((1/2) * (e^(x) + e^(-x))) =>
(e^(x) - e^(-x)) / (e^(x) + e^(-x))
12 / 13 = (e^(x) - e^(-x)) / (e^(x) + e^(-x))
12 * (e^(x) + e^(-x)) = 13 * (e^(x) - e^(-x))
12 * e^(x) + 12 * e^(-x) = 13 * e^(x) - 13 * e^(-x))
25 * e^(-x) = e^(x)
25 = e^(2x)
ln(25) = 2x
2 * ln(5) = 2x
x = ln(5)
sinh(x) =
(1/2) * (e^(x) - e^(-x)) =>
(1/2) * (5 - (1/5)) =>
(1/2) * (24/5) =>
12/5
cosh(x) =
(1/2) * (e^(x) + e^(-x)) =
(1/2) * (26/5) =>
13/5
But I believe there must be a graphical explanation using hyperbola too, just as there are algebraic and graphic explanations for trigonometry using circles and triangle.
Can someone explain it to me graphically using hyperbola?
It is just the same as the circle, but using the unit hyperbola instead of the unit circle. Also, ##x## is not a regular angle, but a hyperbolic angle. The unit hyperbola can be parametrised by a hyperbolic angle ##\theta## as
x = \cosh(\theta), \quad y = \sinh(\theta),
since this implies that ##x^2 - y^2 = 1##. Draw a line through the origin and ##x = 13, y = 12##. Where it crosses the hyperbola, the ##x##-value is ##\cosh(\theta)## and the ##y##-value is ##\sinh(\theta)##. Of course, to do this you will need to draw the hyperbola properly first.
However, your problem is more easily solved using the hyperbolic identity ##\cosh^2(\theta) - \sinh^2(\theta) = 1## to relate ##\cosh(\theta)## and ##\sinh(\theta)## to ##\tanh(\theta)##. You do not need to go via the definitions in terms of exponential functions.
x=12 and y=13 does not cross the origin but just a straight line parallel to x and y-axis at x=12 and y=13 respectively. I guess you may have meant it with respect to θ but could you elaborate on it?
You have misread the post. There is only one line. It passes through the origin and the point ##(x,y) = (12,13)##. Two points are sufficient to uniquely identify a line.
