Explanation for Rayleigh Criterion?
4 replies · 9K views · last reply
ameliatqy
Explanation for Rayleigh Criterion??
I just want to ask what is the reason behind Rayleigh criterion which states that items are just resolved when the maxima of a diffraction pattern coincides with the first minima of the other diffraction pattern. I have tried finding the answer but to no avail. Can anyone help?
Thank you for your help in advance!
Everyone's eyesight is different. Some people can probably resolve apart two 'Airy discs' if they are a little closer together than the RC, others might need them to be somewhat further apart than the RC. The RC is a handy 'rule of thumb', rather than having a strict optical basis. And, as a rule of thumb, it's very easy to use: you can simply say that two stars (or whatever) are resolvable (resoluble?) if they're separated by an angle of [itex]1.22\frac{\lambda}{d},[/itex] in which [itex]\lambda[/itex] is the wavelength of the light and d is the aperture diameter.
This is a practical definition that ensures the presence of a noticeable dip between the two peaks, and makes the heights of the peaks correct since each is summed with zero from the other.
The Rayleigh criterion is just one choice for resolution, however--others exist as well, each with their own rationale.
A picture is worth 1000 words:
Three diagrams of two overlapping intensity peaks labeled Resolved, Rayleigh Criterion, and Unresolved, showing the peaks separating progressively less from left to right.
(From http://hyperphysics.phy-astr.gsu.edu/hbase/phyopt/raylei.html )
Perhaps it's worth noting that the Rayleigh criterion is not the only criterion for resolvability, it's simply the one developed during the era of film (continuous detectors) and applies to mutually incoherent (independent) sources. Two other important criteria in use today are the Sparrow criterion:
http://www.opticsinfobase.org/view_...eq=0&mobile=no&org=Cleveland State University
http://www.biomachina.org/courses/structures/082.pdf
And the Johnson criterion, which is appropriate for sampled imaging systems:
http://en.wikipedia.org/wiki/Johnson's_criteria
