Exponential Growth And Composite Functions
6 replies · 2K views · last reply
ardentmed
Hey guys,
Few more questions for the problem set I've been working on. I'm doubting some of my answers and I'd appreciate some help.
Question:
The first one starts off easy but I found that it gets progress more challenging later on. So the rate of spread should be p'(t) which is:
p'(t) = 5/[e^.5t * (1+10e^(-.5t))^2]As for 1b, I just used chain rule and product rule together to get:
f''(x) = 6xy'(x^2) + 4(x^3)g''(x^2)And finally, for the second question, if the tangent it horizontal, then dy/dx = 0, right?
Therefore, you solve for x, which leads you to:
sinx=-1
x=arcsin(-1)
x= -π/2Which leads to ( -π/2 , 0 ) as the co-ordinates after substituting x = -π/2 into the original function.
Thanks in advance.
ardentmed said:
Hey guys, ...And finally, for the second question, if the tangent it horizontal, then dy/dx = 0, right?
sinx=-1
x=arcsin(-1)
Thanks in advance.
For the second question:
$$y'=-\frac{\mathrm{sin}\left( x\right) }{\mathrm{sin}\left( x\right) +2}-\frac{{\mathrm{cos}\left( x\right) }^{2}}{{\left( \mathrm{sin}\left( x\right) +2\right) }^{2}}$$
so: $y'=0$ means:
$$\begin{aligned}
-\frac{\mathrm{sin}\left( x\right) }{2+\mathrm{sin}\left( x\right) }-\frac{{\mathrm{cos}\left( x\right) }^{2}}{{\left( 2+ \mathrm{sin}\left( x\right) \right) }^{2}}&=0,\\
\sin(x)(2+\sin(x))+(\cos(x))^2&=0,\\
2\sin(x)+1&=0,\\
\sin(x)&=-1/2 \dots
\end{aligned} $$
Horizontal Tangent Lines
Question 1: =Under certain circumstances a rumor spreads according to the equation p(t) = 1/(1+10e^(−0.5t)) ,
where p(t) is the proportion of the population that knows the rumor at time t.
constants.
Find the rate of spread of the rumor.
Question 2: Find the coordinates for the points on the curve where y= cos(x)/(2+sin(x)) $0\le x\le 2\pi $ is horizontal. The first one starts off easy but I found that it gets progress more challenging later on. So the rate of spread should be p'(t) which is:
sinx=-1
x=arcsin(-1)
Thanks in advance.
so: $y'=0$ means:
$$\begin{aligned}
2\sin(x)+1&=0,\\
\sin(x)&=-1/2 \dots
\end{aligned} $$
Alright, so with that in mind, I re-did the question and computed:
arcsin(-1/2) = x
Thus,
x= 11$\pi$ /6, 7$\pi$ / 6.
Giving the points
(11$\pi$ /6, 2/√3) and (7$\pi$ / 6 , -2/√3)
I agree with your derivation of $p'(t)$, but do not see question 1b).
For the second question, yes, we want to require $$\d{y}{x}=0$$. But, you have not found the correct condition, and since you have not shown your work, I have no idea where you went wrong. Please show your work in computing the derivative.
I have merged two threads together since they are the same questions. Do you see how double posting lead to me duplicating the efforts of zzephod? I value my time, and don't want to see it wasted, nor do I want to see the time of others wasted as well.
Please do not create a new thread dealing with questions you have already posted.
My apologies for the oversight.
Regardless, I did it again and came up with the same answer:
arcsin(-1/2) = x
Therefore, this value can be computed by drawing out the 45 degree triangle with 1-1-√2 sides. Therefore, the solutions should be 2π - π/4 = 11π /6, and π + π/4 = 7π / 6
Thus,
x= 11π /6, 7π / 6.
Giving the points
(11π /6, 2/√3) and (7π / 6 , -2/√3)
