Expression of Gravitational Potential in GR
neelakash
Hello everyone...can anyone tell me what is the modified expression for the gravitational potential in GR which takes into account the fact that the speed of gravity is finite (c, to be precise)...In fact, it may be a non-sense question as I haven't started to read GR yet...Is there any correction factor that involves c and the relative velocity of the two bodies?
--Neel
There isn't any such thing as "gravitational potential" in full GR, though you'll see the Newtonian potential used in various places, such as weak-field GR, or in the PPN approximation to GR. One of the reasons for this is that gravity isn't a force in GR as it is in Newtonian theory, it's a curvature of space-time. You can't explain "gravitational time dilation" - i.e. that a clock at a higher altitude will seem to tick more rapidly than a clock at a lower altitude - using just the idea that gravity is a force, for instance. However, the curvature of space-time does explain why the clocks appear to tick at different rates.
While it's true that the speed of gravity in Newtonian gravity is infinite and it's finite in GR, this is not the most fundamental difference between the theories.
Static spacetimes can be described by a scalar potential, but the OP seems to have non-static spacetimes explicitly in mind. See http://www.lightandmatter.com/html_books/genrel/ch07/ch07.html#Section7.3 , subsection 7.3.7.
There is also a sense in which the metric can be considered to be the gravitational potential -- but it's not a scalar.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. The Relativator was sold by (as printed) Atomic Laboratories, Inc. 3086 Claremont Ave, Berkeley 5, California , which seems to be a division of Cenco Instruments (Central Scientific Company)... Source: https://www.physicsforums.com/insights/relativator-circular-slide-rule-simulated-with-desmos/ by @robphy
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
