Extending reals with logarithm of zero
In summary, the conversation revolves around the idea of extending the real numbers with the logarithm of zero, as well as the validity and rigor of such an extension. One person mentions that it may be possible in a restricted sense, but questions the necessity of doing so. Another person shares their opinion that this idea is nonsensical and lacks rigor. The concept of regularization and the Cauchy principal value are also brought up as potential methods to define the logarithm of zero. The conversation ends with a reference to the Euler-Mascheroni constant and a link to a related discussion on another website.
Anixx said:
What do you guys have to say about this Mathoverflow post?
I think ##\zeta(-1)=-1/12## is already adventurous enough and this is an attempt trying to imitate Ramanujan's result here. However, while ##\zeta(-1)=-1/12,## can rigorously be deduced, I cannot see any rigor deduction that avoids the pole of the zeta-function at ##x=1## in what is said on MO.
To me, it is just playing around with terms and infinity disrespecting the analytical background. E.g.
H_n=\sum_{k=1}^n\dfrac{1}{k}=\log n +\gamma +O\left(n^{-1}\right)
reads on MO
The Maclaurin series of the function ##\ln (x+1)## at ##x=-1## is the Harmonic series with negative sign, thus, we can represent ##\lambda=-\sum_{k=1}^\infty \frac1k##. Since the Harmonic series has the regularized value of ##\gamma## (Euler-Mascheroni constant), the regularized value (finite part) of ##\lambda## is ##-\gamma##.
Sorry, that is nonsense in my opinion, i.e. it does not make any sense to me. How does this regularization work? What is the finite part of infinity? We can yield literally every result we like as long as we avoid any rigor. All I can see is
\lambda =\log (0)=\displaystyle{\lim_{n \to \infty}}\log(n^{-1})=-\lim_{n \to \infty}\log (n)=\gamma -H_{\infty }=\gamma -\infty
which is still a pole of the zeta-function at ##x=1\, : \, \lambda = -\zeta(1)=\gamma -\infty =-\infty .##
Likes topsquark
That the Harmonic series has the regularized value ##\gamma## is a known mathematical fact. Take the Cauchy principal value for instance:
https://www.wolframalpha.com/input?i=Limit[(Zeta[1-h]+Zeta[1+h])/2,+h->0]
The Ramanujan summation gives the same result: https://math.stackexchange.com/a/650515/2513
Likes PeroK
Anixx said:
That the Harmonic series has the regularized value ##-\gamma## is a known mathematical fact. Take the Cauchy principal value for instance:
Yes, and this was the first time you actually mentioned what regularization would mean in this context. Before this quote, it was only a handwavy term without substance. Now, you want to define
\lambda =:\log(0) =:-\displaystyle{\lim_{h \to 0}}\left(\dfrac{\zeta(1-h)-\zeta(1+h)}{2}\right)=:-\gamma
This makes it obvious that we do not need a new constant which is simply the negative Euler-Mascheroni constant.
Do you want to discuss in how far a definition ##\log(0)=-\gamma ## would make sense? If so, can you prove that this is a complex continuation of the zeta-function at ##x=1?## No. And here is where we are back at
topsquark said:
But why would you need to do this?
Here is a nice list of what we already know about ##\gamma ##
https://en.wikipedia.org/wiki/Euler's_constant
Likes topsquark
The problem lies in the formula
\gamma =\lim_{s \to 1} \left(\zeta(1)-\dfrac{1}{s-1}\right)
Just because ##\gamma ## is the difference between two diverging sequences, it doesn't allow us to take it to define another infinite quantity.
Likes dextercioby and topsquark
Euler-Mascero
fresh_42 said:
If so, can you prove that this is a complex continuation of the zeta-function at ##x=1## No.
The Cauchy principal value of Zeta function at ##x=1## is ##\gamma##.
Also, take a look here: https://math.stackexchange.com/a/4083388/2513
Likes PeroK
Obviously I have never defined ##\lambda=-\gamma##. If you read the post more carefully, you will see that ##-\gamma## is the finite part (which is the same as regularized value) of ##\lambda##.
Likes PeroK
So you want to discuss the meaning of the Cauchy principal value?
Anixx said:
... and the comments there. It makes no sense to discuss something with a constant reference to another website.
Likes topsquark
Cauchy principal value is a method of regularization.
See the quotation in post #3. If you now attach a different meaning to "we can represent" other than equality, then this is exactly what I meant by a lack of rigor.
Likes topsquark
I made a link to the post that has no comments. It describes another way to see how the regularized value of the integral ##\int_0^1 \frac1x dx## is ##\gamma##.
Emphasis by me.
So? I still try to figure out what you are aiming at. Giving ##\log(0)## some finite value? What for? The Cauchy principal value isn't even substitution invariant! It is not of much use IMO.
Likes topsquark
In that quotation I wrote that we can represent ##\lambda=-\sum_{k=1}^\infty \frac1k##, yes. The regularized value (the finite part) of the right hand is ##-\gamma##.
fresh_42 said:
What for? The Cauchy principal value isn't even substitution invariant! It is not of much use.
As you can see from the original post, while ##\gamma## is neither a period (member of ring of periods), nor an EL-number, ##\lambda## is both. Thus it has more nice properties.
Also, from that same post we can see that in dual numbers ##\varepsilon^\varepsilon=1+\varepsilon(1+\lambda)##, and many other nice properties.
Including, for instance, representation of some divergent integrals:
##\int_0^\infty \frac{\ln t}{t} \, dt=\gamma\lambda+\gamma^2/2##
If you want to seriously consider ##\lambda ## then you have to answer a few questions, regardless of what is written on MO.
  1. What is your goal?
  2. How is ##\lambda ## defined?
  3. Why did you choose ##\log(0)## and not any other pole of another function?
  4. How is it different from ##-\gamma ##?
  5. What do we get, what we don't already know from ##\gamma ##?
  6. What should renormalization here provide?
  7. Do you want to discuss Cauchy principal values?
  8. Do you want to discuss Ramanujan sums?
  9. Do you want to discuss regularization in general?
  10. Do you want to discuss Riemann's zeta function?
Likes topsquark
1. Investigation of extending reals
2. ##-\int_0^1 \frac1x dx##
3. Hmmm. This is not a pole.
4. ##-\gamma ## is its finite part. ##\lambda## is negatively infinite.
5. To be honest, ##\gamma ## is a constant that does not have a lot of nice properties (except being the real(finite)part of logarithm of zero). On the other hand ##\lambda## appears in nice relations.
6. If you mean regularization, it provides the finite part (in this case, real part).
7. No
8. No
9. No
10. No
Likes PeroK
This is a slogan, not a goal.
What does ##\mathbb{R}\cup \{\lambda\} ## do?
This is merely a sequence of symbols. If we read it as an integral, then this is not defined as the integral does not converge. You cannot work with infinity this way.
It is.
... of what?
So you want to extend the real numbers by ##\pm \infty ##? This is a well-known concept, even if not generally suited to solve problems.
Have you looked at the many formulas that contain ##\gamma ##? Look again at my Wikipedia link.
Especially, as it isn't defined!
1. It is described in the linked post what can be done with this extension.
2. It is a divergent integral, and it is well described what is meant. You can work with infinitely large values quite well.
3. Logarithmic singularity is not a pole.
4. Of divergent integral ##-\int_0^1 \frac1x dx## and of divergent series ##\sum_{k=1}^\infty -\frac1k##
4a. "So you want to extend the real numbers by ##\pm\infty## ?" Obviously, not. Do you think, the ##\pm\infty## compactification is the only one possible? Have you heard about Hardy fields or formal power series?
Likes PeroK
It looks to me like either you're rediscovering something that mathematicians already know, in which case you should be able to find a mainstream reference somewhere, or you're doing personal research, which is off limits here at PF--if you think you've made some new mathematical discovery, you need to publish it in a journal, not here.
No, it is not. But anyway, why don't you repeat it here?
You can cheat with infinite large values quite well. That's why I demand a rigorous definition.
So far you defined ##\lambda =-\int_0^1 t^{-1}dt ## which is not a well-defined expression. It is symbolism.
In my language, it is a pole. Maybe not in English although I doubt that. But it doesn't really matter what you call it. It is a location where the logarithm is not defined. Call it as you like.
You can just pick a divergent series or integral and play with it. It simply does not make any sense to me.
I haven't seen any formal power series in the entire discussion until now.
Related to Extending reals with logarithm of zero
1. What is the purpose of extending reals with logarithm of zero?
The purpose of extending reals with logarithm of zero is to create a more complete and consistent number system that can handle calculations involving zero and negative numbers. It also allows for a wider range of mathematical operations to be performed.
2. How is this extension different from the traditional real number system?
This extension differs from the traditional real number system in that it includes the value of logarithm of zero, which is undefined in the traditional system. This allows for a more complete representation of numbers and their properties.
3. What are the implications of including logarithm of zero in this extension?
The inclusion of logarithm of zero in this extension has significant implications in mathematical calculations involving zero and negative numbers. It allows for the evaluation of expressions that were previously undefined and provides a more accurate representation of real-world phenomena.
4. How does this extension impact the concept of infinity?
This extension does not directly impact the concept of infinity, as it still remains an unattainable value. However, it does provide a more precise understanding of the behavior of numbers approaching infinity, particularly in logarithmic functions.
5. Are there any limitations to this extended number system?
Like any mathematical system, there are limitations to this extension. For example, it does not apply to all types of mathematical operations and may not be applicable in certain contexts. Additionally, it may introduce some complexities in calculations and may not be easily understood by those unfamiliar with the concept.
  • Linear and Abstract Algebra
  • Calculus
  • Other Physics Topics
  • Science and Math Textbooks
  • Differential Equations
