Extension in spring with unequal forces acting on its two ends
The discussion focuses on the mechanics of a spring system with two masses, m1 and m2, connected by a spring of spring constant k, subjected to forces F1 and F2. The correct formula for the extension of the spring when F1 > F2 is derived as x = (m2*F1 + m1*F2) / (k*(m1 + m2)). The participants clarify that in a frictionless environment, the spring still experiences extension due to the forces acting on the masses, emphasizing that an unstretched spring exerts zero force. The conversation highlights the importance of clearly stating assumptions in physics problems.
  • Understanding of Newton's laws of motion
  • Knowledge of Hooke's Law and spring constants
  • Familiarity with basic mechanics involving forces and mass
  • Concept of acceleration in a multi-body system
  • Study the derivation of Hooke's Law and its applications in mechanics
  • Explore systems of equations in physics, particularly in multi-body dynamics
  • Learn about frictionless surfaces and their implications in mechanical systems
  • Investigate the effects of different force magnitudes on spring extension
Physics students, mechanical engineers, and anyone interested in understanding the dynamics of spring systems and force interactions in mechanics.
@bhishek
Two masses m1 and m2 are connected by by spring of spring constant k. If two forces F1 and F2 acts on the two masses respectively in mutually opposite direction (i.e. outwards) what would be the extension in the spring and the acceleration of the two masses.
I think that if assuming F1>F2
then the extension in spring should be equal to x= F2/k
and the forces acting on m1 would be F1 in forward and kx(F2) in backward direction.
and on m2 F2 in backward and kx(F2) in forward direction.
Where am I wrong in my assumption?
If the spring force equaled F2, what would be the net force on m2? Is that reasonable?
Thanks
Thank you. I noticed were I was wrong.
In this case the eqn would be
F1-kx = m1*a
kx- F2 = m2*a
Solving we would get
x= (m2*F1+ m1* F2)/(k)(m1+m2)
F1-kx = m1*a
kx- F2 = m2*a
Looks good to me.
Note that you are solving for the special case where there is no relative motion of the masses--the spring extension remains constant.
Doc Al said:
Looks good to me.
In the same special case with no relative motion if we put m1=m2 and F2=0 (the surface is friction-less, I forgot to mention it earlier) then the extension in the spring comes to F1/(2*k)
Then how could there be extension when there is no friction acting on the masses?
Right. (I has assumed there was no friction since you did not mention any.)
Why would you need friction?
There seems to be something wrong with this problem statement. There appear to be 3 unknowns (the relative displacement x, and the acceleration of each of the two masses a1 and a2), but only two equations.
Chet
We are assuming no relative motion of the masses, so there is a single acceleration. (That assumption should have been made explicit in the problem statement.)
If the surface is friction less then why should there be any extension in spring. Shouldn't the spring be able to pull the block m2 without any extension?
A spring cannot pull without extension. (An unstretched spring exerts zero force.)
The force exerted on m1 drags the entire system along. Some of that force is transmitted to m2 via the spring.
That solves the problem. :D
  • · Replies 17 ·
  • · Replies 19 ·
