Factoring polynomial over rings
The polynomial x^3 + 3x + 6 can be factored over various rings, with specific results for Z5, Z10, Z, Q, and ℝ. In Z5, the factors are (x + 3)²(x + 4), while in Z and Q, the polynomial is irreducible due to Eisenstein's criterion. For Z10, multiple roots exist, including x = 1, 2, 6, and 7, leading to non-unique factorizations due to the presence of zero divisors. The real roots can be computed using a substitution method, yielding complex expressions for the roots.
  • Understanding of polynomial factorization
  • Familiarity with modular arithmetic, specifically Z5 and Z10
  • Knowledge of Eisenstein's criterion for irreducibility
  • Experience with substitution methods for solving cubic equations
  • Study polynomial factorization techniques in modular arithmetic
  • Learn about Eisenstein's criterion in depth
  • Explore the implications of zero divisors in non-prime rings
  • Practice substitution methods for solving cubic equations
Mathematics students, educators, and researchers interested in polynomial algebra, particularly those working with modular arithmetic and factorization techniques.
llstelle
Factor x^3+3x+6 over Z5, Z10, Z, Q and ℝ.
2. The attempt at a solution
For Z5, I have the roots of x^3+3x+1 in Z5, x=2=-3 and x=3=-4, so x+3 and x+4 are factors. By long division of x^3+3x+1, it is found that x+3 is a repeated factor, so x^3+3x+6=(x+4)(x+3)^2.
For Z and Q, Eisenhart's criterion is satisfied with 3, hence x^3+3x+6 is irreducible over Q, and hence Z.
For Z10 and ℝ... I don't really get how to do this problem. Is there a consistent way to work out the factors for Z10? It seems like a lot of effort. Also, I noticed that x^3+3x+6 has one real root over ℝ, and so I can factor it neatly to a linear factor (with real root) and a quadratic factor with two complex roots, but I only managed to get these roots with a computational method - and they have pretty long but explicit expressions, so again, my question: is there a proper way to work out the roots by hand here?
Thanks!
Welcome to PF, llstelle! :smile:First off, x=3 is not a root in Z5, but x=1 is.
For Z10 you only need 1 root. Is perhaps x=1 or x=2 also a root in Z10?For R, I think you're stuck with the complicated solutions.
But here's a general method that gives the answer fairly easily:Starting with x^3+3x+6=0.
Substitute x=y+z, meaning you have a free choice for either y or z.
So (y+z)^3+3(y+z)+6=0
\Rightarrow (y^3+z^3+3y^2z+3yz^2) + 3(y+z)+6=0
\Rightarrow y^3+z^3+3(yz+1)(y+z)+6=0Choose z such that yz+1=0, or z=-{1 \over y}
Then: y^3 - {1 \over y^3} + 6 = 0
\Rightarrow (y^3)^2 + 6(y^3) - 1 = 0Solve as a quadratic equation and back substituting z gives:
x=y+z=\sqrt[3]{-3 + \sqrt{10}} - {1 \over \sqrt[3]{-3 + \sqrt{10}}}
or
x=y+z=-\sqrt[3]{3 + \sqrt{10}} + {1 \over \sqrt[3]{3 + \sqrt{10}}}
Note that both solutions are the same root.
Hello! Oh oops, that was a typo - yes I have x=1 as a root of the equation for Z5. And thanks for the general solution for ℝ! I've never done that before. I've been taught to test numbers until I find a root, then divide the cubic equation by the linear factor to find a quadratic factor, and use the general solution for a quadratic equation for the quadratic factor.. ): This is so much neater!
OK, I tried each of them for Z10 and I have x=1, 2, 6 or 7 satisfying f(x)=0. If I write (x+9)(x+8)(x+4)(x+3), I get a fourth order polynomial whose fourth order term does not vanish in Z10... How does this happen? Something looks wrong to me.
:smile:
A polynomial of degree n can have more than n roots in Zn if n is not prime.
For instance, x^2-1 has 8 roots in Z24: \pm 1, \pm 5, \pm 7, \pm 11.
And would probably indicate that x^3+3*x+6 doesn't have a unique factorization. Z10 has zero divisors. You can probably find several factorizations.
  • · Replies 18 ·
  • · Replies 27 ·
  • · Replies 17 ·
