Failed function within SMPS giving weak current
The discussion revolves around diagnosing a weak current issue in a switched-mode power supply (SMPS) that outputs a stable voltage but delivers current significantly lower than its rated capacity. Participants explore potential causes, components involved, and troubleshooting approaches.
  • Experimental/applied
  • Some participants suggest that a common culprit could be a faulty component, such as an output FET or an issue with the overcurrent protection circuit.
  • Others emphasize the importance of understanding the specific SMPS topology and the need for oscilloscope measurements to diagnose the problem accurately.
  • There are mentions of potential issues with the control circuit or the inductor causing high ripple current, which could lead to weak output current.
  • Some participants question whether the voltage remains stable under load, suggesting that the behavior of the output during loading should be observed.
  • A few participants express skepticism about the feasibility of repairing a typical power brick, suggesting that it may be more practical to replace it instead.
  • One participant notes that if the output voltage is correct but the current is low, it may indicate that the load is drawing only what it needs, rather than a fault with the power supply.
Participants do not reach a consensus on the exact cause of the weak current issue. Multiple competing views and hypotheses are presented, with some advocating for troubleshooting while others suggest replacement as a more practical solution.
Participants highlight the lack of specific details about the SMPS, such as its topology and schematic, which complicates the diagnosis. There are also references to the challenges of working with encapsulated or potted power supplies, which may hinder repair efforts.
This discussion may be useful for individuals troubleshooting power supply issues, particularly those interested in electronics repair, power supply design, or those facing similar symptoms in their devices.
abdulbadii
TL;DR
faulty component function within SMPS leading to have weak current
What is the very common culprit component and what is its
function within SMPS having weak current, far weaker than its rating while its voltage is always perfect?
Something with a heat sink. One of the output FETs.
abdulbadii said:
TL;DR Summary: faulty component function within SMPS leading to have weak current
Which power supply is it? Do you have a schematic?
It could be as simple as an over current protection circuit failing. Without knowing more details it's hard to say.
Also, I assume the "voltage is always perfect" part does not include when you start to load the output, right? Have you used an oscilloscope to watch what the output does in this early current limit behavior? Many SMPS will use a "burp" mode to try to recover during/after an overcurrent condition. Most linear power supplies will crowbar the output voltage and not attempt to recover until the overcurrent condition is removed. Which do you see on your oscilloscope?
There are way too many possibilities here. We don't even know the SMPS topology you are referring to. Of course something wrong with the control circuit could do that. Also for a very commonly used current-mode controlled SMPS, a problem with the big inductor creating high ripple current.
If you don't know how your PS works, you'll just be guessing. If you think you can fix it by just replacing one thing, you may just be delaying another failure due to an undiagnosed underlying cause. The key troubleshooting step here is to somehow get access oscilloscope measurements of the various currents (transistors, inductors, rectifiers, etc.). This is really hard to do if you aren't in a lab set up for such things.
So, since you're asking us instead of working quietly at your lab bench, I suggest throwing it out and buying one that works as intended.
--- Wait ---That's after you are sure your external measurements are correct and your application is compatible with the PS specifications. We all can fool ourselves with bad data and blame the wrong thing.
PS: If it's an encapsulated brick, no one can fix it, throw it out.
One trick you can try to figure things out is to find the datasheet for the control IC and look at their applications and functional description. These ICs are nearly always used just as the manufacturer intended, adjusted of course for the PS specifications. If the magnetics has an off-the-shelf part number you can do the same with that to get current ratings and inductance or turns ratios, but this is rarely the case, magnetics are almost always custom designs.
It's what around us, typical kind and size one that is for laptop, printer, or router etc
input 110-240 V 1.6 A 50-60Hz
output 24 V
2.5 A
read once only max 700 mA, all reading else mostly 400-500 mA
its outstanding Led contradict its performance; its light last long, won't off until around one minute after disconnected from mains power
output 24 V
2.5 A
Woo-wee. So it's a cheap power brick that no longer seems to work. Just buy another one; you are not going to pull apart an ultrasonically welded plastic brick to repair it.
If it were disassembled it could be a learning experience. No worries if it gets wrecked. But dealing with anything potted is not fun.
In my experience power bricks are just ultrasonically welded plastic enclosures, not fully potted. Even so, without a schematic (which we are not getting for a jellybean power brick like this), even I would not try to debug it. (Unless it were my design and it was returned from a customer under RMA.) :wink:
abdulbadii said:
output 24 V
2.5 A
Erm.
As long as the 24V is fine, if the current is lower than 2.5A then it's about the load, not about the brick.
Why do you think it's wrong?
@Rive got it right, if the output Voltage is correct but the Current is low then the Power Supply is good; it is just because the item being powered takes only the Current it needs to operate. Any higher current the supply has available can be used to power other stuff at the same time.
  • · Replies 42 ·
11K
  • · Replies 23 ·
