Fairly complex trig integration
The discussion revolves around the integral \(\int \frac{dx}{\cos x + \cos 3x}\), which falls under the subject area of trigonometric integration. Participants explore various approaches to manipulate the expression and evaluate the integral.
  • Participants discuss the transformation of the integral and question the steps taken to simplify the expression. There are attempts to clarify the relationship between \(\cos x\) and \(\cos 3x\) through trigonometric identities. Some participants express uncertainty about the validity of certain steps and seek further clarification on the manipulations involved.
The discussion is ongoing, with participants providing feedback on each other's attempts and suggesting the need for clearer steps in the derivations. Some participants have indicated they have received help from teaching assistants, which may guide their reasoning, but no consensus has been reached on the correctness of the approaches discussed.
There is a noted confusion regarding the original problem statement, with one participant admitting to a mistake in their earlier posts regarding the sign of the cosine terms. This highlights the importance of careful attention to detail in mathematical expressions.
hanelliot
\int dx/(cosx + cos3x)
Not sure if I'm doing this right.
1/cosx + cos3x = 1/2cosx * cos2x = cosx/cosx * 2cosxcos2x = cosx/2cos^2xcosx = (1/2)*(cosx)/[(1-sin^2x)(1-2sin^2x)]
then we let t = sinx and get \int dx/(cosx + cos3x) = 1/2 [1/(1-t^2)(1-2t^2)]dt
Any comments please..
Please use more parentheses.
How did you get from the first expression to the second?
1/(cos(x) + cos(3x)) = 1/(2cos(x)cos(2x))
it was a hint given by a TA.. I plugged in few numbers and the relationship seems to hold?
It may be true, but you can't really prove that it is by merely plugging in a few numbers. In any case, it's not obvious, so you should put in the intervening steps.
\frac{1}{cosx + cos3x}= \frac{1}{2cosx cos2x}= \frac{cos x}{cosx * 2cosxcos2x} = \frac{cos x}{2cos^2xcosx }= \frac{cosx}{2(1-sin^2x)(1-2sin^2x)}
Here's what you posted in the first post, using tex tags.
Show how you get from the first expression to the second.
From the 2nd to the 3rd, you apparently multiplied by cos x /cos x, which is fine.
From the 3rd to the 4th is fine.
From the 4th to the 5th, I think you have an error.
Finally, in your integral, show the step where you make the substitution but before you actually integrate.
Thank you for your reply.. I worked out a new solution, can u see if anything's wrong?
<br /> \int \frac{dx} {cosx-cos3x} =<br /> \frac{1}{4} (-(\frac{1}{2}) cot(\frac{x}{2}) - ln(cos(\frac{x}{2}) - sin(\frac{x}{2})) + ln(cos(\frac{x}{2}) + sin(\frac{x}{2}) - (\frac{1}{2}) tan(\frac{x}{2})) + C<br />
Why don't you check it yourself? If your answer is correct, its derivative ought to be your integrand. In my previous post I asked you to show how you got from the first expression to the next in your string of equalities, but you haven't done so.
using identities:
cos(3x) = cos(2x+x) = cosx cos2x - sin^2x sinx
cos(x) = cos(2x-x) = cosx cos2x + sin^2x sinx
2nd term cancels out and we get 2cosxcos2x at the bottom. I got some help from my TA and solved it, thanks for your help!
hanelliot said:
using identities:
I get
cos(3x) = cos(2x+x) = cosx cos2x - sin2x sinx
cos(x) = cos(2x-x) = cosx cos2x + sin2x sinx
So cos(x) - cos(3x) = cosx cos2x + sin2x sinx - cosx cos2x + sin2x sinx = 2sin(2x) sin(x)
That's not the same as what you show below...
original question is actually cos(x) + cos(3x), not minus.. I made a mistake in post #5
