Falling of the box in the accelerationg train
The discussion centers on determining the minimum acceleration required for a cuboid to tip over in a train without slipping. The key factors include the inertial force acting on the cuboid due to the train's acceleration and the frictional force preventing slipping. It is established that the cuboid will tip backward if the inertial force exceeds the frictional force at the edge of its support. The solution involves analyzing the moments about the center of mass of the cuboid to find the critical acceleration threshold.
  • Understanding of Newton's laws of motion
  • Knowledge of static friction and tipping points
  • Familiarity with moments and torque calculations
  • Basic principles of dynamics in non-inertial reference frames
  • Study the concept of tipping points in rigid body dynamics
  • Learn about calculating moments about the center of mass
  • Explore the effects of static friction on motion and stability
  • Investigate the dynamics of objects in accelerating frames of reference
Students in physics, particularly those studying mechanics, as well as educators and anyone interested in the dynamics of objects in non-inertial frames.
ldv
A cuboid of constant density, height h and length of bottom side=L is in the train. Determine the minimal necessary acceleration (of the train) needed for the cuboid to fall. There is no slipping.
(that's all that is stated in the text)
not sure, probably the friction, and the inertial force
I don't really know where to start, it will fall (backwards? =opposite to the direction of the acceleration) because of the inertial force? but there is also friction involved, since there is no slipping?, and this falling of the box is actually the rotation around the bottom side? and the force of inertia has to be greater than the force of friction?
please just some hint about what is going on in this situation!
Welcome to PF!
Hi ldv! Welcome to PF! :smile:
Anything will start to tip if the reaction force reaches the edge of its support.
The question assumes that the box does not slip, but it will tip over backwards if the train accelerates fast enough.
Hint: in what direction and where is the force making the box accelerate? where is the normal reaction force?
take moments about the centre of mass of the box. :wink:
  • · Replies 37 ·
  • · Replies 18 ·
10K
