Falling solid cylinder with string
37 replies · 5K views
Suyash Singh
m:mass of solid cylinder
T: tension in string
w:angular velocity
m(g-a)=T
mg-ma=T
a=v^2/r=w^2r
now what?
haruspex said:
How do you get that?
its the equation for centripetal acceleration
BvU said:
More equations needed ! :smile:
Centripetal force = mv^2/r for cylinder
And what role does that play here ?
What about the relation between ##\omega## and ##T## ?
What is ##I## ?
Make a sketch to see where forces act (free body diagram)
What is ##I## ?
Tension = m(g-a)+mrw^2
The only centripetal forces are internal to the cylinder. They have no consequence for the rate at which the cylinder descends.
You need to think about angular acceleration and its relationships to torque and to linear acceleration.
Dr Dr news said:
I think T = W and a = (2/3) g
Please do not post answers at such an early stage. This is a homework forum. The idea is to provide hints, correct misunderstandings and point out errors.
Did you read the guidelines?
My bad. You might start by considering the motion to be about the contact between the cylinder and the string like considering the motion of a tire down the road by analyzing the motion of the tire about the contact with the road.
Dr Dr news said:
I think T = W ...
The tension would be equal to the weight only if the acceleration is zero. See OP's equation in #1, mg - ma = T.
Tension=I alpha
where I is moment of inertia
and alpha is angular acceleration
Tension=1/(2) (MR^2) alpha
but what is alpha?
oh ok so i found this formula
a=r alpha
So T= 1/(2) (mr^2) a/r
=1/2 mra
Also
T=m(g-a)
comparing we have
1/2mra=m(g-a)
1/2ra=g-a
(r/(2)+1)a=g
r+2/2=g/a
r+2=2g/a
a=2g/r+2
now what?
Suyash Singh said:
T= 1/(2) (mr^2) a/r
Not quite. You are using T as a force, but on the right you have Iα, which is not a force. What have you forgotten?
Torque=I alpha
haruspex said:
Right, so what is the torque in this case?
torque is the tangential force
No, a torque is not a force. How do you find the torque of a force about an axis?
torque=R F sin(theta)
where theta is the between R and F
Right, so correct your equation in post #15 and go from there.
T= mr alpha
T=m(g-a)
r alpha =m(g-a)
a=mg-ma
a(m+1)=mg
a=mg/m+1
Suyash Singh said:
T= mr alpha
No, you had
Suyash Singh said:
T= 1/(2) (mr^2) a/r
but the T is a force not a torque. Just replace the T with the torque that T exerts about the centre of the cylinder.
haruspex said:
No, you had
what do you mean?
Suyash Singh said:
what do you mean?
What is the torque that the tension T exerts on the cylinder about the cylinder's axis?
Torque=I alpha
=1/2 mr^2 a/r
=1/2 mar
=1/2 T r
If you are taking moments about the string-cylinder contact point, you need to use the parallel-axis theorem.
Suyash Singh said:
Torque=I alpha
No, I mean using the equation you wrote in post #21 what is T's torque about the axis of the cylinder?
Dr Dr news said:
If you are taking moments about the string-cylinder contact point.
I see no evidence that Suyash is doing that.
