Designing a Faraday Generator Suit | Get Answers Here
  • Thread starter Thread starter GoldenTurtle
    Faraday Generator
The discussion focuses on designing a Faraday Generator suit, which incorporates small Faraday generators into clothing to charge devices like cell phones and iPods. Key components include copper wiring, neodymium magnets, and plastic tubes, with specifications of a maximum diameter of one inch and a length of three inches. The power output of these generators is determined by the size of the coil and the intensity of the magnetic field, with the relevant formula being e = N(dΦ/dt). Concerns about the practicality and bulkiness of such a suit were raised, suggesting that alternative energy harvesting methods may be more efficient.
  • Understanding of electromagnetic induction principles
  • Familiarity with Faraday's law of electromagnetic induction
  • Knowledge of basic electrical engineering concepts
  • Experience with energy harvesting technologies
  • Research the design and construction of Faraday Disc Generators
  • Explore energy harvesting techniques from body movements
  • Investigate the efficiency of neodymium magnets in energy generation
  • Learn about the applications of wearable energy harvesting devices
This discussion is beneficial for electrical engineers, product designers, and researchers interested in wearable technology and energy harvesting solutions.
GoldenTurtle
Hello everyone, I need help designing a Faraday Generator suit.
It's basically a bunch of small Faraday generators (the kind used in flashlights), sewn into the fabric of outer clothing and connecting to batteries to charge them.
The problem is that I have no idea what it will take to make these small generator tubes.
I'm hoping for a max diameter of an inch and a max length of 3 inches.
I plan on using simple copper wiring, neodymium magnets, and plastic tubes.
Could you guys please fill me in on some equations I need to know, and how much power a single one of these generators can produce in an hour of steady, continuous use?
Thanks.
what is the application of this suit for? i don't see y one would want to wear a suit of generators. it seems...painful.
It's to charge a cell phone, iPod, or multiple devices.
And they're sewn in so that they don't even touch the skin, they're embedded into gloves, boots, etc.
So are you going to HELP me or what?
i suppose the beginning then is do you know how to build a a Faraday Disc Generator?
They're NOT DISCS.
They're just like those rechargeable flashlight Faraday generators.
The power generated is dependent on the size of the coil that you create and the intensity of the magnetic field.
i believe this is the formula that you may be looking for however
e = N(dΦ/dt)
Mentor note: I had to edit this thread a bit to keep it on track.
GoldenTurtle -- sparkey is just pointing out that a suit like you propose, based on a number of induction coils responding to bounces of movement, would be bulky and heavy, and probably would not be the optimum way to harvest energy from body movements. I think this issue has been addressed elsewhere, and will see if I can find some info. You can also google something like energy harvesting from body movements...
  • · Replies 26 ·
  • · Replies 18 ·
17K
