FBD of Flexible and Rigid Body Coupling
ThLiOp
Problem:
I am having a bit of problem with the signs on the force balance with the constraining force. The system is:
Schematic of a tapered bar fixed at the left wall with properties P(x), EA(x), distributed load f(x,t) and displacement u(x,t) over length L, connected through a spring k and damper c in parallel to a lumped mass M with displacement y(t) and output force p(t).
Attempt:
I drew the FBD with the constraining force for the lumped mass:
Free-body diagram of a block labeled M with displacement y(t) shown by an arrow above it pointing right, a force Q(t) arrow pointing left from its left side, and a force p(t) arrow pointing right from its right side.
Then I tried to solve for the constraint force in terms of the spring and damper:
Free-body diagram of a lumped mass M with displacement y(t) to the right, a leftward constraint force Q(t), and rightward-acting arrows labeled k(y-u(L,t)) and c(dy/dt-du/dt) on its right side.
For the constraint force, Q(t), I end up getting:
Q(t) = k[u(L,t) - y] + c[(du/dt) - (dy/dt)]
The answer that the professor gives has the signs changed on the k and c terms. Where am I going wrong?
Thank you!
  • Diagram of a tapered bar fixed to a wall on the left, with distributed load f(x,t) and displacement u(x,t), connected at its right end through a spring k and damper c in parallel to a lumped mass M with displacement y(t) and output force p(t).
  • Free-body diagram of a block labeled M with displacement y(t) shown by a rightward arrow above it, a force Q(t) pointing left and a force p(t) pointing right acting on the block.
  • Free-body diagram of a lumped mass M with displacement y(t) to the right, a constraint force Q(t) pointing left, a spring force k(y-u(L,t)) pointing left, and a damper force c(dy/dt-du/dt) pointing left.
The expression you wrote for Q(t) is positive when u(L,t)>y And the same for derivatives. Now look at your FBD; it shows positive Q to the let. There is your sign error.
