Fe+ Brine Solution forcing by Earth Tides
  • Thread starter Thread starter Squatchmichae
    Brine Earth Tides
Taylor Glacier in Antarctica features a unique Fe2+ brine solution, resulting in a rusty discharge known as Blood Falls. Seismic data from the area shows strong diurnal signals that are not linked to cultural or other geophysical factors. The discussion centers on calculating the maximum force or stress that this confined brine solution can exert on its walls due to Earth Tides, using a median value of magnetic susceptibility for concentrated Fe brine. While the mechanics and math involved are complex, the challenge invites Fermi-type solutions from those with expertise in the field. The provided resources, including links to relevant articles and Earth Tides data, may aid in addressing this unique problem.
Is this interesting to you?
  • Yes
    Votes: 0 0.0%
  • No
    Votes: 0 0.0%
  • Not Appropriate Here
    Votes: 0 0.0%
  • More like this
    Votes: 0 0.0%
  • Total voters
  • Poll closed .
Squatchmichae
Here is a esoteric problem that is totally unique in nature: Taylor Glacier, in the Dry Valleys of Antarctica, hosts site of a Fe2+ brine solution, expressed as a rusty discharge at the terminus. There is strong diurnal signals in seismic data gathered from an array co-located there, not attributable to cultural, or other geophysical inputs.
Blood Falls Information site: http://en.wikipedia.org/wiki/Blood_Falls
Challenge: with a median value of magnetic susceptibility for concentrated Fe brine, and assuming volumes on the order of cubic meters (not cubic km, for example), what is the maximum force or stress that a confined solution (subglacially) can exert on it's walls, driven by Earth Tides alone?
Earth Tides Data: http://geomag.usgs.gov/
It's outside my expertise (mechanics, math mostly) but someone might have a Fermi-type solution.
I did some quick searches and found an interesting article about Taylor Glacier, which is where this brine is located. It's called Blood Falls, and from what I read it appears that this brine has been there for over a million years. This article (http://en.wikipedia.org/wiki/Blood_Falls) might provide some insights into the problem. The Earth Tides Data link provided looks like a valuable resource as well. Good luck!
Thread 'Question about pressure of a liquid'
I am looking at pressure in liquids and I am testing my idea. The vertical tube is 100m, the contraption is filled with water. The vertical tube is very thin(maybe 1mm^2 cross section). The area of the base is ~100m^2. Will he top half be launched in the air if suddenly it cracked?- assuming its light enough. I want to test my idea that if I had a thin long ruber tube that I lifted up, then the pressure at "red lines" will be high and that the $force = pressure * area$ would be massive...
I feel it should be solvable we just need to find a perfect pattern, and there will be a general pattern since the forces acting are based on a single function, so..... you can't actually say it is unsolvable right? Cause imaging 3 bodies actually existed somwhere in this universe then nature isn't gonna wait till we predict it! And yea I have checked in many places that tiny changes cause large changes so it becomes chaos........ but still I just can't accept that it is impossible to solve...
