Fidelity between initial and final states
85 replies · 6K views
deepalakshmi
TL;DR
Evolution of state |0>|alpha>
I have a state |0>|alpha>. Now I want to evolve this state at any time t and find the fidelity between the initial and final states. Any ideas how to do that? My main problem is that I don't know how to evolve this state.
Do you have the Hamiltonian of the system? If so, you can get the final state by solving Schrödinger's equation.
I have evolved the state and the final state is $|\alpha isin\theta>$ |\alpha cos\theta>$. Now how to find the fidelity between initial and final state?
I am not sure what you mean by fidelity here.
Typically "fidelity" means approximately "how likely something is to work"
That is, the fidelity for an operation (aka gate) that takes you from |0> to |1> would be 1 if you always end up in the |1> state.
This means that calculating the fidelity only really makes sense if there is some "randomness" if in your calculation, either because you are averaging over many runs with slightly different parameters; or because you have included noise and/or decoherence in your calculations (in the simplest case using something like a Lindblad approach)
Can I omit sin and cos terms and consider only alpha terms? Can I do like that?
Another doubt is that is my initial and final state pure state?
Since they are expressed in some certain states, they are both pure.
I think purity, fidelity as you need, coherence, and entanglement can be studied via density matrices.
Now that you mentioned pure states, I strongly suggest that you should learn density matrices or density operators.
Your states seem to be a bipartite system. Now you want to study the first particle. This can be done via, again, density matrices. Just construct them for your states, and then partial trace out the second particle, and you will get what you want. Generally, the matrices you got will represent mixed states.
Here I have two state in initial state. How to find density operator for biparitite system?
I can't understand. Can you explain it briefly?
No, you only have one state for the initial state, i.e., ##\left | \psi \right >=\left | 0 \right >\left | \alpha \right >## as a whole.
You can easily construct its corresponding density matrix by ##\rho=\left | \psi \right > \left <\psi \right |## since it is a pure state.
I refer you to Nielsen M A, Chuang I. Quantum computation and quantum information[J]. 2002. section 2.4 and Sakurai J J, Commins E D. Modern quantum mechanics, revised edition[J]. 1995. section 3.4.
I think they are sufficient for you.
Then what about final state?
Still ##\rho=\left | \psi \right >\left<\psi \right |## because you gave a pure state.
Since here both the states are pure should I use F=|<\psi| \fi >|^2 ?
Now according to my question psi is the initial state and fi is the final state. So I have to find the inner product of $|\alpha>|o> with |\alpha>|\alpha>$. How to find that?
I am not sure what are |\alpha>|o>and |\alpha>|\alpha>.
But when calculating the inner product, always match states for the same particle together.
For example, the inner product for ##\left | 0 \right >_1 \left | 1 \right >_2 ## and ##\left | 2 \right >_1 \left | 3 \right >_2 ## is given by $$\left < 0 \right |_1 \left < 1 \right |_2 \left | 2 \right >_1 \left | 3 \right >_2= \left < 0 \right . \left | 2 \right >_1 \left < 1 \right . \left | 3 \right >_2 .$$
Like you said i tried to find the inner product of |α⟩|0⟩ and |α⟩|α⟩
This is my calculation
<α|<0| |α⟩|α⟩= | <α|α⟩ <0|α⟩ |^2 where <α|α⟩=1. But what is <0|α⟩? Is my calculation correct?
What is ##\ket{\alpha}##? Without that information we know nothing at all useful about whatever problem it is you are trying to solve.
PeterDonis said:
How is anyone supposed to know that if we don't know what ##\ket{\alpha}## is?
##\ket{\alpha}## is coherent state
That narrows it down, but there is more than one possible "coherent state". Can you be more specific?
##e^{-\frac{|\alpha|^2}{2}}\frac{(\alpha)^n}{\sqrt{n!}}|n>##
You have just answered the question of what ##\braket{0 \vert \alpha}## is; just plug ##n = 0## into the above formula.
can't understand. How can I just replace n with 0?
As you write it, this state doesn't make sense; these don't look like meaningful kets. What Hamiltonian are you using?
##H=(\hat{a}^\dagger \hat{b}+\hat{b}^\dagger \hat{a})##
You have a formula for ##\ket{\alpha}## in terms of the number operator eigenstates ##\ket{n}##. The number operator eigenstate for ##n = 0## is ##\ket{0}##. Since number operator eigenstates are orthogonal, when you evaluate ##\braket{0 \vert \alpha}##, the only term in ##\alpha## that matters is the ##\ket{0}## term, whose coefficient is given by your formula with ##n = 0##.
The ##\hat{a}## operator and its counterpart make sense here (as the ladder operators for the number operator eigenstates ##\ket{n}##, but what do the ##\hat{b}## operators act on?
@deepalakshmi it might help if you would give more context about the problem you are trying to solve. Where did this initial state and the Hamiltonian come from? What physical situation are you modeling?
