Filled Julia set - check my solution if it is right.
  • Thread starter Thread starter foxofdesert
    Set
The discussion focuses on finding the value of R such that |f(z)| > |z| for |z| > R, where f(z) = z^3 - 27z + 15. The user proposes that R = 5 based on the roots of the equation z^3 - 28z + 15 = 0, identifying 5 as the furthest point. However, there is uncertainty about this solution, as it is suggested that at z = 5, f(5) = 0, indicating that |f(z)| may not exceed |z| in that vicinity. The conversation emphasizes the need to determine where |f(z)| - |z| > 0 to confirm the correct value of R. The user seeks validation of their approach and understanding of the problem.
foxofdesert
Suppose f(z) = z^3 -27z + 15
Find R such that |f(z)|>|z| whenever |z|>R.
Let f(z)=z, then I have z^3 -28z + 15 = 0
then,
z=5, (-5+√(17))/2, (-5-√(17))/2.
since 5 is the most further point, R=5.
check my solution if it is right. I did it, but I am not so sure.
so at z=5, f(5) = 0 and at z=5+e, for some small e>0, f will still be pretty small, so I don't think you've nailed it
you need to find where
|f(z)|-|z|>0
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
